Activity Forums Apple Final Cut Pro Legacy pulldown for 720p 23.98 shot on varicam
  • pulldown for 720p 23.98 shot on varicam
    Posted by Clayton Woodhull on January 30, 2007 at 6:40 pm
    Hey –
    I am Assisting on a show that is shot on Varicam and cut DVCPRO HD 720P 23.98 in Final Cut Pro. We are capturing from and outputting to the Panasonic AJ-1200HD deck.
    Another default in the 720p easy setup is a 2:3:2:3 pulldown in the System settings. Should I change that setting to Advanced Pulldown (2:3:3:2)?
    I also hear the 1200 deck has some issues recording the flags for 23.98.
    Also, I have been told that the frame blending mode in Final Cut needs to be unchecked as it causes interlacing issues not suitable for broadcast. (The default is checked.)
    Any other advice would be appreciated.
    Gary Adcock has said the default 2:3:2:3 is correct because advanced pulldown should only be used in interlaced modes.
    Excuse the double post in the Varicam Forum.
    Clayton
    Clayton Woodhull replied 19 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    January 30, 2007 at 7:10 pm
    [clayton]
    Another default in the 720p easy setup is a 2:3:2:3 pulldown in the System settings. Should I change that setting to Advanced Pulldown (2:3:3:2)?”
    I don’t see ADVANCED PULLDOWN being an option for DVCPRO HD. That is a setting for DV. No, just choose the DVCPRO HD 720p24 setting and FCP will do the rest. The varicam inserts flags onto the tape that indicate what format the footage is. So if it is 23.98, FCP will capture it 23.98. If it is 59.94, FCP will capture it 59.94…no matter what easy setup you choose. This is why I have to log and capture…my DP constantly switches so that I can have footage to slow-mo later.
    [clayton] “Also, I have been told that the frame blending mode in Final Cut needs to be unchecked as it causes interlacing issues not suitable for broadcast. (The default is checked.)”
    Frame blending should be unchecked…correct. But, if the footage is 24p, then there are no frames to blend…
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Gary Adcock
    January 30, 2007 at 10:10 pm
    From My NAB Training class about 24p Universal Mastering.
    About Pulldown…
    Cadence is referring to the redundant or duplicate frames/ fields that are added so that 24p (23.98) content will playback properly in the 60i world broadcast lives in. However with variable frame rates that cadence can change based on the frame rate being shot and the video stream the content is being recorded in. This is called a “telecine”
    a shortening of “television from cinema” or the process used to playback film content on a television. Removing these frames is called a reverse telecine.
    Shoot 24p with Standard 3:2 pulldown for:
    You get the
  • Clayton Woodhull
    January 31, 2007 at 1:19 am
    “Hence the reason why there is not Advanced pulldown with progressive sources it is not necessary, the progressive content does not need to worry about a bad “C” frame that was recombined from different parts within the 4 fields of 2 different interlaced frames.”
    The reason I ask is that since there obviously will be a pulldown when I go out to tape and I have the option of making it advanced (in the system settings – playback tab) or normal, I want to make sure I am not forcing fields to blend by choosing normal which is the default for 720P DVCPRO HD. We want to stay 23.98 the whole way through. The D5 master will be 23.98, so I just want to make sure I’m not messing with the flow.
  • Gary Adcock
    January 31, 2007 at 1:54 am
    [clayton] ” The D5 master will be 23.98, so I just want to make sure I’m not messing with the flow.”
    Clayton
    This is the first mention of D5 – your first sentence in the first post said you were capturing from and recording to a 1200a.
    “The reason I ask is that since there obviously will be a pulldown when I go out to tape and I have the option of making it advanced (in the system settings – playback tab) or normal” and once again I am telling you that no one uses the advanced pulldown with progressive material and if you do with the cross conversion to your 1080 24psf master on D5 it will not work.
    gary adcock
    post instructor at HD expos Varicamps
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Clayton Woodhull
    January 31, 2007 at 2:09 am
    Yes, we will be upconverting the DVCPRO HD output to a 1080 23.98 D5 for archival.
