Activity Forums Apple Final Cut Pro Legacy Pulldown Clarification
  • Pulldown Clarification
    Posted by Scott Kleinberger on July 20, 2009 at 4:02 pm
    First, although I have never posted I have used this site for the great resource that it is. Thanks.
    I am hoping for a little clarification.
    I have a XDCam EX sequence shot st 23.98 cut into a FCP sequence with an AJA Kona LHe card. The sequence setting s I am using are for 1080i/29.97. I am under the impression that from within the RT Menu the user can select the type of pulldown FCP is introducing.
    I have seen different post around this website that seem to conflict. Some post indicate FCP only uses 2224 pulldown, other say it is selectable through the RT menu. I have selected the 2323 option.
    Does anyone want to weigh in definitively?
    Thanks.
    -scott
    Aaron Neitz replied 17 years, 1 month ago 3 Members · 2 Replies
  • John Pale
    July 20, 2009 at 7:26 pm
    The kona adds pulldown to a 23.98 sequence not a 29.97 sequence with 23.98 footage in it.
  • Aaron Neitz
    You want your 23.98 media in a 23.98 timeline.
    what you have now, 29.97 timeline, FCP simply duplicates whole frames to fill in the gap. Step through and you should see dupe frames.
    So you have a 23.98 timeline, if you select 1080i/29.97 as your Kona VIDEO OUT, then you get the RT menu options for pulldown.
    2:3:2:3 is the standard 3:2 interlace scheme. The other two are advanced pulldown and the 2224 is a pulldown for slower computers.
