Activity Forums Adobe After Effects Expressions pull layer’s comp name?
  • pull layer’s comp name?
    Posted by Alex Printz on November 8, 2018 at 4:00 pm
    Hey all, quick expression question:
    If I have declared a layer in a variable:
    L = comp("Comp 1").layer("Shape Layer 1");
    can I later pull the comp name for L? e.g. (doesn’t work)
    N = L.propertyGroup(1).name
    or do I need to declare them individually?
    C = comp("Comp 1");
    L = C.layer("Shape Layer 1");
    n = C.name;
    I would really prefer to declare as a single line (as this will half the time be pickwhip’d, half not), so if it’s at all possible I’d love to hear!
    Alex Printz
    Mograph Designer
    Alex Printz replied 7 years, 10 months ago 2 Members · 4 Replies
  • Dan Ebberts
    November 8, 2018 at 4:36 pm
    The second one. Expressions don’t have anything like the containingComp attribute that’s available in scripting.
    Dan
  • Alex Printz
    November 8, 2018 at 5:49 pm
    Actually, it turns out that you can. After a bit of experimenting, you can grab the comp :
    n = L.thisComp.name;
    Strangely, if you do this, you cannot grab the layer the same way:
    R = comp("Comp 1").layer("Shape Layer 1").content("Rectangle Path 1");
    n = R.thisLayer.name
    but you can do this:
    n = R.propertyGroup(2).name
    Alex Printz
    Mograph Designer
  • Dan Ebberts
    November 8, 2018 at 6:23 pm
    I’m really surprised that this works. The expression language reference lists thisComp as a global object representing the comp containing the expression, but it must really be a layer attribute, with the layer defaulting to thisLayer.
    thisLayer.thisComp.name
    (which I would expect to throw an error) gives the same result as:
    thisComp.name
    You learn something every day I guess…
    Dan
  • Alex Printz
    November 9, 2018 at 3:16 pm
    Yeah that was really unexpected now that I’m looking at adobe reference page. Interesting that it can be referenced via the layer. Might have to play around with that some more.
    Alex Printz
    Mograph Designer
