Activity Forums Apple Final Cut Pro Legacy Puling a Still Frame to Print on a Poster
  • Puling a Still Frame to Print on a Poster
    Posted by Rory Keenan on April 1, 2012 at 12:01 am
    I need to pull a still frame from from our footage to be printed on a poster.
    I have done this but the image is not great quality (looks slightly pixelated), especially when poster size.
    I tried exporting the frame as TIFF, JPEG and a Photoshop documents…..all with the same result.
    The exported still images were 1920×1080 pixels (same as footage)
    The director insists there is a way to export these images that will be good quality for print……he says he’s done it with standard def footage.
    However I’m not so sure.
    There were stills shot on the location which look much sharper (because they are approx 4000×2500 pixels)
    Our footage is 1080p 29.97fps shot on a Cannon Mark V.
    Is there a trick I’m missing?
    Any Suggestions??
    Jerry Hofmann replied 14 years, 5 months ago 9 Members · 9 Replies
  • 9 Replies
  • Misha Aranyshev
    April 1, 2012 at 2:28 am
    That director is full of BS. 1920×1080 frame looks good printed at 6.4″x3.6″. It may look ok at 9.6″x5.4″. Anything bigger will look like crap.
  • Shane Ross
    April 1, 2012 at 3:00 am
    And they are only 72dpi…SD or HD, doesn’t matter. 1920×1080 72dpi is the best it gets.
    Shane
    Little Frog Post
  • Rafael Amador
    April 1, 2012 at 3:33 am
    [Rory Keenan] “There were stills shot on the location which look much sharper (because they are approx 4000×2500 pixels)”
    With this he can expect something a bit better, but tell him don’t expect miracles.
    They may try some Photoshop plugin to improve the upscaling.
    As Michael said, with 1920×1080 you can get something around 6.4″x3.6″ with average printing quality (300dpi).
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    April 1, 2012 at 1:52 pm
    Video resolutions are NOT print quality.
    Chris Tompkins
    Video Atlanta LLC
  • David Roth weiss
    April 1, 2012 at 4:31 pm
    [Michael Aranyshev] “That director is full of BS. 1920×1080 frame looks good printed at 6.4″x3.6″. It may look ok at 9.6″x5.4″. Anything bigger will look like crap.”
    Precise on all accounts…
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    http://www.ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Bret Williams
    April 1, 2012 at 5:51 pm
    They’re whatever DPI you want them to be. Up to 1920 DPI. You simply change the DPI in your print program (PS) or it will do it for you depending on how you set the scaling parameters in the image size dialog. 6.5″ wide is what you’ll get for 300dpi. The image will be printed 6.5″ wide and will be 300dpi.
  • Bret Williams
    April 1, 2012 at 5:54 pm
    They are at a particular size. SD was another story. But with HD you’re able to grab a decent rez magazine shot. But they’re often blurry due to the slow shutter speed or camera movement. Just not the same as a nice sharp still.
  • Mark Suszko
    April 2, 2012 at 2:05 pm
    You could try the Genuine Fractals program for upscaling, or whatever it is they call it now – it doesn’t add rez, it uses fractals to make the rez you have work over a larger scaled size.
  • Jerry Hofmann
    April 2, 2012 at 3:51 pm
    Great answer for sure.
    I’ll bet we’ll see a day shortly where someone like AJA, Teranex or other will upscale HD to 4k in a hardware up conversion, you print from that…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
