Activity › Forums › Apple Final Cut Pro › Publishing titles from Motion
  • Publishing titles from Motion
    Posted by Jason Jenkins on December 27, 2011 at 9:58 pm
    So I’ve been playing around with publishing some basic animated title templates in Motion. I can see great potential here as I used to go back to After Effects to make title changes, then render and import. The ability to make FCPX editable templates will be a real time saver once I figure out the details.
    When I put my 10 second title template on the FCPX timeline, it shows up as a 25 second clip. The animation itself is only 10 seconds, after which the clip is straight alpha channel. If I try to trim the clip down to its original length, it gets retimed instead of trimmed; i.e. the full animation will be 5 seconds long instead of 10. Anyone have any tips?
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
    Tom Wolsky replied 14 years, 9 months ago 2 Members · 5 Replies
  • Tom Wolsky
    December 27, 2011 at 10:44 pm
    Make the title into a compound clip, and trim the compound clip.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Jason Jenkins
    December 27, 2011 at 10:46 pm
    OK, I figured out that I can set a “loop end” marker in Motion and that will fix the length of the title animation in FCPX; i.e. I can trim the title without retiming it. However, the title is still coming in at 25 seconds long and it’s looping the 10 second animation.
    Jason Jenkins
    Flowmotion Media
  • Jason Jenkins
    December 27, 2011 at 10:48 pm
    [Tom Wolsky] “Make the title into a compound clip, and trim the compound clip.”
    That will certainly work, Tom; but it’s a band-aid solution. I’m looking for the root cause and a cure!
    Jason Jenkins
    Flowmotion Media
  • Jason Jenkins
    December 27, 2011 at 10:57 pm
    [Jason Jenkins] “OK, I figured out that I can set a “loop end” marker in Motion and that will fix the length of the title animation in FCPX; i.e. I can trim the title without retiming it. However, the title is still coming in at 25 seconds long and it’s looping the 10 second animation.”
    It looks like I had a couple of empty groups floating around in my Motion timeline that gave it the extra length. I deleted them and all is well. 🙂
    Jason Jenkins
    Flowmotion Media
  • Tom Wolsky
    December 27, 2011 at 10:58 pm
    Root cause may be in Motion. Frame rate maybe?
    All the best,
    Tom
