Activity Forums Apple Motion Publishing a title copy
  • Publishing a title copy
    Posted by Tom Fox on March 22, 2013 at 5:05 pm
    Hello all,
    I trying to edit a copy of FCPX’s “Dramatic” Title generator in Motion.
    I have set the scale slider to “publish” so that I can adjust the timing. The problem is that though the animation seems to work fine in Motion, when placed on the timeline in fcpx , the text is static.
    Is there something simple that I am doing wrong?
    Cheers,
    T
    Tom Fox replied 13 years, 6 months ago 2 Members · 2 Replies
  • Alex Gollner
    March 23, 2013 at 12:24 am
    If the scale slider is published, you can now set scale keyframes in Final Cut Pro to change the value for scale over time.
    A way of using a different sets of keyframes that have been set in Motion is to assign each set to a rigged widget.
    @Alex4D
    ___________________________________________________
    Alexandre Gollner,
    Editor, Zone 2-North West, London
    alex4d on twitter, facebook, .wordpress.com & .com
  • Tom Fox
    March 23, 2013 at 10:09 am
    Hi Alex,
    A closer study showed that the z-index, as opposed to scale, was used in the above effect. No matter, I made z index publishable, but there is still no movement in fcpx.
    Is it therefore the case that if a parameter is published then it is essentially re-set in fcpx? And that one has to create a widget to override that?
    I am away from my kit this weekend so cannot look.
    Love your blog/work btw.
    T
