Activity › Forums › Adobe Encore DVD › PSD Menu Image Rollover Question
  • PSD Menu Image Rollover Question
    Posted by Michael Noes on May 19, 2008 at 8:23 pm
    Hello, I’m not terribly proficient in Encore, but I can make your basic menu in Photoshop and bring the PSD into encore as the dvd menu.
    The problem that I’m experiencing is that the rollover images that I make on the menu items (programmed as “(=)” in the .psd) only come through as a solid color. For example, if my rollover image is a gradient, or has lots of colors, then Encore seems to pick one of those colors and make the rollover, in whatever shape it was, a solid color. Is there any way around this? Is there any way to create true IMAGE rollovers, and not simply solid-color shapes?
    I’m using Encore CS3.
    Thanks in advance
    Mike
    David Garrett replied 18 years, 4 months ago 3 Members · 4 Replies
  • David Garrett
    May 20, 2008 at 1:23 pm
    The DVD spec only allows the use of 1 solid colour for a highlight, or a combination of 3 seperate different solid colours..
    You have to cheat to get the efect you want, in other words you need multiple menus along with the auto activate feature of Encore…
  • Michael Noes
    May 20, 2008 at 6:30 pm
    Thanks David, the sneaky way it is then.
    I’ve done a bit of searching as to this workaround, and come up dry- could you explain the process?
  • Joe Bowden
    May 20, 2008 at 7:33 pm
  • David Garrett
    May 20, 2008 at 7:35 pm
    if you go here https://www.doogs-tutorials.com/encore%201.5%20.html and look to tuts #09 and #10 in the advanced section (red section), the tuts will give you a rough idea as to how to go about it.. (you may have to copy and paste the above link into your browser..
    hope these help..
