Activity › Forums › Adobe After Effects › PSD Increasing Renders
  • PSD Increasing Renders
    Posted by Dan on July 14, 2008 at 10:51 pm
    Just a little problem, I will give the basics. Project consists of two text fields doing a simple x-position move, 6 Quicktime Movie files, no moves, just playing. Two of those are alpha keys. 1 Movie file is set up with in “add” mode. 3 Movie file is set up at 100% size. Two PSD’s equal in size, doing an x, y move, scale from 70% to 50%, as well as a dissolve on. The PSD’s animation stopping in 4 seconds.
    So extremely simple. Render time in After Effects 7.0.1 is 2 minutes and 22 seconds. Render time in After Effects CS3 8.0.2 using multi-processors checked or unchecked, takes…… 1 hour and 55 minutes.
    Final movie file Rendered is 20 seconds long when complete.
    Does this make any sense or is there a new secret preferense like holding down some keys to show a preference file I am not seeing???? Frustration????
    Dan replied 18 years, 2 months ago 23,477 Members · 1 Reply
  • Dan
    July 15, 2008 at 4:16 pm
    Answered. The Ability for using the Track Mattes in After Effects CS3, is almost useless…. Increased Render times to 1 hour to 30 minutes. Used masking in After Effects to rebuild masks, and done. Render took 1 minute.
    Go figure….????….
