  • Posted by Per Ottesen on December 4, 2007 at 3:00 pm
    We are having problem on a FCP-machine (Studio 2), when importing PSD files (layered files), it comes in as text (Bin: ABC), but when we try the exact same PSD file on another machine, it works perfectly with a new sequence with all the layers, so the PSD file is OK.
    We have tried deleting the Pref-files and deleting the Cache memory, but it didn’t help.
    The ONLY difference is, that there ain’t any Photoshop program on the machine, but should that be necessary to make a proper import ?
    Any suggestions will be appreciated 😉
    Phil Lauter replied 18 years, 9 months ago 2 Members · 3 Replies
  • Phil Lauter
    December 20, 2007 at 5:28 pm
    I an also having a problem with the .psd import, BUT here is what I do know. I imported a .psd file from the Advanced Color Correction and Effects in Final Cut Pro – DVD Apple Certified training book/course that worked fine. I do NOT have Photoshop of my editing MacPro Dual Core. But when I create a .psd on another PC and another Mac – no good. It comes in as a flattened pic. I’m at a loss!
    Did you ever figure anything out??
    Phil
  • Per Ottesen
    December 21, 2007 at 11:54 am
    Hi Phil!
    No, I still haven’t any clou
  • Phil Lauter
    December 21, 2007 at 5:08 pm
    Per,
    Here is one thing I have noticed. I can import a single pict file with an alpha channel. So, I just have to break out the psd into all of it’s layers, and import them separately. Kind of a pain, but at least I can get the job done.
    Another thought I have not checked on: I am using some old Photoshop 5 software, on both the Mac and the PC. I wonder if an upgrade to 7 would allow the psd to import?
    What Photshop version are you running?
    Phil
