Activity Forums Apple Final Cut Pro Legacy psd files look like garbage when importing into fcp
  • psd files look like garbage when importing into fcp
    Posted by Jeff Blasczyk on December 2, 2005 at 6:18 am
    i have been importing text files into fcp at 480x720x72 and they look pixelated when i play them on the timeline and export them to quicktime. does anyone know why this is? what file types are best used in fcp?
    Shane Ross replied 20 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    December 2, 2005 at 11:30 am
    #2 Playback is blurry
    Shane’s Stock Answer #2:
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL NTSC MONITOR, OR AT LEAST A TV.
    1. Disable overlays on the canvas
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline
    https://docs.info.apple.com/article.html?artnum=24787
    DV footage requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or NTSC monitor routed thru your camera or deck.
    And putting any graphic into a DV timeline instantly compresses it 5:1…that is the nature of DV.
