PrPro-AE with audio syncing- Help
Ok, so this is kind of hard to explain. I synced 15 videos to an audio track in Premiere Pro, making the mistake of not getting each video the same length- it looks something like this (they are synced to the green audio track)-
. I then linked each video as a comp. into Ae and started compositing. All worked well up until here. Then I brought in my final BG animation into AE and brought all the linked comps into a new comp. Now when I bring the new linked comp into Premiere Pro, the videos won’t be synced to the audio. The reason of the new comp. is I want to track the position of each clip onto the BG.
Any ideas what I can do about the syncing problem?
