Activity Forums Adobe After Effects Proxies have a RED Background
  • Bartek Skorupa
    March 23, 2010 at 8:13 am
    First check out if you have set the output of the proxy so that it renders with alpha.
    If so, everything is fine.
    Check out the image below. Is this your situation?
    If so – you have the background of you comp set to be red. You can change it back to it’s default black by Cmd-Shift-B, and change the color to what you want. If you want to see the alpha grid – click this guy:
    Is this the issue?
    Bartek Skorupa
    Warszawa, Poland
