Activity › Forums › VEGAS Pro › ProTitler – changing keyframe times
  • ProTitler – changing keyframe times
    Posted by Brian Scott on October 15, 2007 at 2:05 pm
    Is there a way to change only the time of the keyframes? Whenever I try to slide them on the timeline, the values change as well. Also – is there a way to jump to the next or previous keyframe?
    Douglas Spotted eagle replied 18 years, 11 months ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    October 15, 2007 at 6:11 pm
    In the area above or below the keyframes, you can drag/select the keyframes (they’ll look like targets/circle around keyframes). Drag them to wherever you’d like.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Brian Scott
    October 16, 2007 at 12:53 pm
    When I try that I end up changing the value as well. Is there a way to only change only the timing?
    October 16, 2007 at 12:57 pm
    Hold ALT as you drag them.
    VASST
