Activity › Forums › Apple Final Cut Pro Legacy › ProRes422 and Shake.
  • ProRes422 and Shake.
    Posted by Adam Taylor on June 27, 2007 at 9:10 am
    I know this is the FCP forum, but it is relevant…i just tried rendering out from Shake using both sd and hd flavours of ProRes422.
    Each time the rendered file shows up as a bright pink screen, with very little other image info visible. It shows the same in FCP and also if i re-open it in shake its still pink.
    Not sure if i’m doing anything wrong, but ProRes422 doesn’t seem to work right with Shake.
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Adam Taylor replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
