Activity › Forums › Apple Final Cut Pro Legacy › ProRes plays smoothly on QTPlayer but Freezes on Final Cut
  • ProRes plays smoothly on QTPlayer but Freezes on Final Cut
    Posted by Rudah De paula on February 22, 2010 at 8:00 pm
    I’m having a problem with a ProRes footage I shot with the GH1.
    When I use the Quick Time Player it works perfectly, but when I try to play it on Final Cut Pro, the image freezes after a few frames, even though the play head is running.
    I’m using a MacPro (2x 2GHzDual Core Intel Xeon, 5GB 667MHz)
    Any ideas?
    Thank You
    Rudah
    Michael Gissing replied 16 years, 7 months ago 2 Members · 3 Replies
  • Michael Gissing
    February 22, 2010 at 8:53 pm
    Check your easy setup to make sure they match the codec settings. Also check the sequence settings to make sure they match the codec settings exactly.
  • Rudah De paula
    February 22, 2010 at 9:28 pm
    Hi Michael,
    Now it’s working fine.
    Thanks for the help.
    Rudah
  • Michael Gissing
    February 22, 2010 at 11:01 pm
    Thanks Rudah. So many people never get back and say if things are fixed so I appreciate it.
