Activity Forums Adobe Premiere Pro Prores export of photo montage comes out jerky
  • Prores export of photo montage comes out jerky
    Posted by Matt Brodie on May 14, 2015 at 4:49 pm
    I did a quick photo montage for a client with your normal ken burns-style moves on each photo, and need to do a bunch of them. They want a prores hq export that they plan on compressing themselves. I have exported with a number of different settings, but it always seems to come out jumpy rather than smooth zooms or pans.
    I had a similar problem exporting rolling credits and found that the h.264 export was much smoother, but that’s not what the client is asking for.
    Is there a setting I can use to fix this? Is this just a known problem with prores? Is there a better codec I could export to and then convert to prores for success or will I find it jumpy no matter how many codecs I go through to get to prores?
    I have tried frame blending which only made the images that were most jumpy look blurred as well, and I have tried optimizing stills.
    Thoughts?
    Matt Brodie replied 11 years, 3 months ago 2 Members · 2 Replies
  • Vince Becquiot
    May 14, 2015 at 6:28 pm
    Hi Matt,
    Does your sequence frame rate match the export frame rate? If they do and these are just pictures. then it’s most likely a playback issue.
    You need a pretty good CPU/GPU to get smooth HD playback on pans and rushes. Try VLC since it has less overhead than most.
    Vince
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Matt Brodie
    May 14, 2015 at 6:31 pm
    Yeah, I’m a moron, the issue was frame rate. I work almost exclusively in 23.98 but this client prefers 29.97, that solved the problem (mostly, there’s still a tiny bit of jitter here and there, but that is corrected in compression, so I think it’s just an issue in quicktime?)
    My computer is definitely up to the task, 2013 mac pro, I was just too set in my 24p ways. Still haven’t seen a solution to the rolling credits issue though, that I KNOW was the right frame rate in all respects.
