Activity Forums Apple Final Cut Pro Legacy ProRes color shift when playing in FCP
  • ProRes color shift when playing in FCP
    Posted by David Burrows on August 22, 2007 at 4:41 am
    I’ve set up a ProRes HQ sequence in FCP with a frame size od 1828×778, but there is a very noticebale color shift between when I’m playing the sequence and when I’m parked on a frame. In other words the picture looks as it should when I’m parked but washed out when playing. I set up another sequence using the same ProRes HQ setting but with a frame size 1920×1080 and the problem went away. It’s a similar problem I used to encounter when using the Motion JpegA codec – which I thought was just a feature of that particular codec – now I’m not so sure, as it looks to be because of the frame size. Does anyone know why this might be?
    Alexander Feichter replied 19 years ago 8 Members · 13 Replies
  • 13 Replies
  • Andy Mees
    August 22, 2007 at 6:21 am
    i’m guessing that because you have created a non-native frame size so you are losing full realtime … ie what you are seeing when playing is realtime preview quality only, it needs rendering to get full quality
  • Walter Biscardi
    August 22, 2007 at 9:30 am
    You’re viewing this on an external monitor and seeing this issue or in the Canvas?
    In the Canvas, some formats will display exactly as you mentioned, but keep in mind that FCP purposely degrades the Viewer and Canvas displays. It is expected that you will view all work on an external video monitor.
    When you’re playing the video back you’re probably seeing more degradation since it’s an odd frame size and FCP is playing it back in realtime, but most like by dropping the resolution. When you stop, you are seeing a full resolution still.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Rick Diamond
    August 22, 2007 at 1:21 pm
    Walter, that brings up a question I’ve had. Why does the canvas degrade the image? The viewer, showing the original material usually looks good. I use an external monitor but it would be really nice if the canvas image didn’t suck.
    Rick
  • Walter Biscardi
    August 22, 2007 at 1:56 pm
    [Rick Diamond] “Walter, that brings up a question I’ve had. Why does the canvas degrade the image?”
    This improves playback on the external monitor and allows for more realtime effects. I never rely on the Canvas so it doesn’t bother me.
    Media 100 had a better viewer on the computer screen, but again, I never relied on it. We’re always focused on the external monitors.
  • Peter Dewit
    August 22, 2007 at 2:22 pm
    May be a stupid question but is the footage in the timeline marked green on the top? It sounds like you’re getting a preivew playback that may need to be rendered.
    I’d also check your RT settings and make sure they’re at high or dynamic.
  • David Burrows
    August 22, 2007 at 11:21 pm
    Yes – I’m monitoring in the Canvas window only – not through a card onto a broadcast monitor (which does fix the problem) I think Rick (above) does raise an interesting point though – why does FCP degrade the image in the Canvas window if it’s an odd frame size?
  • David Burrows
    August 22, 2007 at 11:26 pm
    Not a stupid question Peter – thanks for responding.
    No I’m not getting a green bar – the clip and sequence settings match each other in every way – it just has this degraded display in the Canvas when playing. I’m happy enough with the reasoning from Walter and others that it is the odd frame size that’s causing the problem – but I’d love to know why FCP is behaving this way..
    Cheers,
    Dave
  • Sean Oneil
    August 23, 2007 at 12:21 am
    David,
    This is an issue that occurs in FCP 6 when it is playing back RGB footage. That’s why you see it with JPEG stuff.
    Could be one of two things.
    1. Check your custom sequence settings, under video processing, and make sure it’s set to render all footage as high-precision YPrPb, not RGB.
    2. This could also be that ProRes doesn’t function properly with custom resolutions. It assumes that non-standard video resolutions are RGB because they would typically be created in a graphics program.
    Sean
  • David Burrows
    August 23, 2007 at 12:50 am
    Thanks Sean,
    Yep, render all footage is set to high-precision YPrPb, not RGB.
    I think you’re correct in putting it down to the fact that I’m using a non-standard frame size.
    Cheers,
    Dave
  • Francois Stark
    August 23, 2007 at 6:36 am
    Next stupid question: Why are you using that strange size?
