Activity › Forums › Apple Final Cut Pro Legacy › ProRes color shift when playing in FCP
Alexander Feichter replied 19 years ago 8 Members · 13 Replies
David Burrows
August 23, 2007 at 6:41 amIt’s a high enough frame size that gives us a 2.35:1 aspect ratio for feature film work…
David Burrows
August 23, 2007 at 6:52 amor to answer your question more accurately..
1828×778 is precisely half the vertical resolution of a 2K cinemascope anamorphic frame on film as recorded through an Arrilaser, and gives huge benefits in terms of resolution vs file size. This meant no interpolation of pixel data apart from fitting the vertical resolution to the anamorphic frame size.
Alexander Feichter
August 24, 2007 at 1:31 pmhmmm, trying to understand…
you do this for avoding interpolation/filtering on downsizing?
if you’d really take only every second line of the original frame the result would have clearly visible aliased edges.
