Activity › Forums › Apple Final Cut Pro Legacy › prores capturing
  • prores capturing
    Posted by Paolo Mugnaini on September 11, 2007 at 7:37 pm
    Hello all, I would like to know if i can capture beta SP in prores….there’s no preset in log and capture for prores. Can I convert it later? if not…do you have any suggestions? I have a lot of material and 1.5TB but my boss keeps saying we should be able to do it in prores. I have looked in alot of places and I couldn’t find anything that said i can use prores with beta sp. i even thought of capturing in DV50 and then render it in prores or 8bit. I don’t know what to do. please help.
    thanks
    P
    Chris Borjis replied 19 years ago 3 Members · 3 Replies
  • Jeremy Garchow
    September 12, 2007 at 12:59 am
    What kind of processor do you have and do you have a capture card?
  • Paolo Mugnaini
    September 12, 2007 at 3:00 am
    MacPro dual, Blackmagic for beta sp.
    I downloaded the 6.4 driver and installed it but it only gives me apple prores HQ and I need the other.I mean that is not in the capture setting menu in log and capture.
    And by the way is there a difference in resolution between Prores 422 and 8bit? I mean if I am capturing betasp in 8bit or prores how much space am i really going to save and what kind of quality just am i getting?
    thanks
  • Chris Borjis
    September 12, 2007 at 4:09 am
    this will work, I do it on a daily basis.
    use the “NTSC ProRes HQ 48khz” easy setup and sequence settings.
