Activity › Forums › Apple Final Cut Pro Legacy › ProRes 4444 not available in Log & Transfer with R3D?
  • ProRes 4444 not available in Log & Transfer with R3D?
    Posted by Brendan Coots on October 24, 2009 at 5:26 am
    I am conducting some tests using RED footage, FCS3 and CS4 Suite to get a handle on best practices for post. The files are in a folder on my local drive so I’m NOT capturing directly from camera.
    It seems that a lot of people are suggesting the use of REDRushes for capturing R3D to ProRes 4×4, but I wanted to run it through FCP 7’s Log & Transfer for testing. I am only getting ProRes422 or HQ as my RED capture options, no 4×4. In another thread it was mentioned that you need a capture card to do this? Is this true even with local footage, NOT from the camera directly? Did I misinterpret that post altogether?
    Thanks in advance
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
    Gary Adcock replied 16 years, 11 months ago 2 Members · 1 Reply
  • Gary Adcock
    October 26, 2009 at 1:06 pm
    [Brendan Coots] “It seems that a lot of people are suggesting the use of REDRushes for capturing R3D to ProRes 4×4, but I wanted to run it through FCP 7’s Log & Transfer for testing. I am only getting ProRes422 or HQ as my RED “
    without a capture card the 4444 setting for ProRes were not installed by default.
    if you go to Applications > Final Cut Pro Additional Easy Setups you will find all of the additional easy setups including the ones for the 4444 codec.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
