Activity › Forums › DaVinci Resolve › ProRes 4444 @ 4K
  • ProRes 4444 @ 4K
    Posted by Robert Due on June 20, 2011 at 9:26 pm
    Hello all,
    I am having trouble getting my files to render out. Here is what I am trying to do:
    Grading off r3d files in a 1080p timeline.
    Trying to render ProRes 4444 @ 4096 x 2304.
    Is this possible? I get about 15 frames in on the render and spinning beach ball. Any help would be appreciated. I need to render 4K because we are doing a lot of blow ups in After Effects.
    Mac Pro Quad Core Intel
    2.93 GHz
    8 Core
    Slot 1: GTX 285
    Slot 2: GT 120
    Help!!!!
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    Robert Due replied 14 years, 5 months ago 7 Members · 12 Replies
  • 12 Replies
  • Dwaine Maggart
    June 20, 2011 at 9:31 pm
    Hi Robert,
    Add the following line to the Debug tab in the DaVinci Resolve Preferences widget, then save, then exit Resolve and relaunch.
    System.Record.Lookahead = 5
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Robert Due
    June 20, 2011 at 9:55 pm
    WOW!!!!!
    Thanks so much. I wish I would have asked that question about 4 hrs earlier.
    Is this solution just to fix ProRes 4444 renders or was it to fix something else? (Like my several force quits I performed throughout the day)
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Dwaine Maggart
    June 20, 2011 at 9:59 pm
    This is a fix for 4K renders. Actually, any renders above 2K should use this.
    Dwaine Maggart
  • Robert Due
    June 20, 2011 at 10:00 pm
    Thanks again. I was ripping my hair out!!!
    Wait. (See picture) 🙂
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Jake Blackstone
    June 21, 2011 at 12:38 am
    Dwaine.
    Could you expand on what this command actually does, beside allowing the 4k render? What is a lookahead?
  • Sascha Haber
    June 21, 2011 at 6:58 am
    … and will that be fixed in v8 ?
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Rohit Gupta
    June 21, 2011 at 7:59 am
    It’s already fixed in v8
  • Dwaine Maggart
    June 21, 2011 at 6:09 pm
    No, I can’t. I think it increases the buffers to the rendering process, but I don’t know the specifics. And as Rohit points out below, the issue has been addressed in V8.
    Dwaine Maggart
  • Mohiudin Mirza
    April 10, 2012 at 12:05 am
    Hi Robert
    Just read your post that you could solve the problem of Davinci Resolve ProRes 4444 4k renders by the Debug Line.
    I tried to enter the same debug line in Resolve but still cant enter any resolution above 1920 in render menu, I got Resolve 8.2 Lite.
    Even if wish to enter 1921 I cant, its like programmed for 1920 max
    Can you please help me
    Regards
  • Mohiudin Mirza
    April 10, 2012 at 12:08 am
    Sir I got Resolve 8.2 Lite,
    I added the debug line System.Record.Lookahead = 5
    but still my render menu is 1920 max cant even enter 1921
    So how do i get 4k renders of ProRes 4444 ?
    please help sir, stuck in decision taking for my current project
    thank you very much
