Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422(HQ) for Online?
  • ProRes 422(HQ) for Online?
    Posted by James Whittington on May 20, 2009 at 6:45 pm
    I just finished a project…the dailies were provided to me as 422(HQ) and that’s the timeline I’ve been working on.
    The client wants an HD finish. Is 422(HQ) technically considered SD or HD? Would there be any difference or benefit from exporting in an HD format? As far as I can tell, if I’m starting with 422(HQ) I might as well finish with that as well. Am I right?
    FYI, most of this will be living on the web. There’s a chance one spot might air and that’s why they want an HD version.
    Thanks!!
    Walter Biscardi replied 17 years, 4 months ago 4 Members · 3 Replies
  • Aaron Neitz
    May 20, 2009 at 6:48 pm
    ProResHQ can be an SD format, but more likely HD. What’s the dimension of the frame? if it’s 1920×1080 pixels, you’ve got HD.
    also it’s a great finishing codec for most everyday HD work. I wouldn’t blink twice about finishing in ProResHQ in all but the most demanding situations.
  • Jeremy Garchow
    May 20, 2009 at 6:51 pm
    [James Whittington] “The client wants an HD finish. Is 422(HQ) technically considered SD or HD?”
    It can be either so it wholly depends on the frame size that was given to you and the original footage
    [James Whittington] “As far as I can tell, if I’m starting with 422(HQ) I might as well finish with that as well. Am I right? “
    Yes, ProResHQ is a high quality 10 bit 4:2:2 codec. It’s the best besides uncompressed.
    Jeremy
  • Walter Biscardi
    May 20, 2009 at 7:19 pm
    ProRes HQ should only be used for HD files larger than 1080i.
    For all other uses, ProRes should be used.
    The codec (ProRes and ProRes HQ) is 10bit regardless of whether it’s used in SD or HD.
    There have been so many threads about this in recent weeks, you can learn everything you ever wanted to know about ProRes in about 5 minutes using the Search function in the forum.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
