Activity › Forums › Adobe After Effects › ProRes 422 HQ HD 1920 x 1080 export to H.264 comes out interlaced!
  • ProRes 422 HQ HD 1920 x 1080 export to H.264 comes out interlaced!
    Posted by Daniel Garcia robles on May 21, 2012 at 10:32 pm
    Hi there, I wonder if someone has come across this issue too?
    I edited some effects on AE CS5 on a ProRes 422 HQ video in a square pixel comp. When I export the video to H.264 the video comes up interlaced with Upper field dominance…
    I am not sure what is wrong? As far as I know all the settings seem fine…
    Any ideas?
    Thanks a lot!
    Daniel
    Kevin Camp replied 14 years, 4 months ago 3 Members · 3 Replies
  • Mathew Fuller
    May 21, 2012 at 11:27 pm
    How can one answer this question if you dont post your settings? Otherwise it’s just guessing.
    The higher they fly… the much.
    My Reel:
    https://www.youtube.com/watch?v=olElCddRiBg
  • Daniel Garcia robles
    May 22, 2012 at 12:14 am
    Hi Matthew, I purposefully avoided providing with any extra details about the settings to avoid confusion as they are the standard ones for HD 1080. (PAL in this case) HDTV 1080 25 Square pixels, 25 fps. I add to the render queue and choose QuickTime>Format options>Video codec H.264.
    That is all I do and then press ok…but comes out with fields…
    Since the project is Progressive and I am not adding fields to the export module…I really don’t know what is generating them…
  • Kevin Camp
    May 22, 2012 at 3:40 pm
    the codec shouldn’t matter (though i would still never render h.264 from ae)… if you wanted to try another codec you could just for troubleshooting.
    if you aren’t add fields in the output module, then i would think the only other place the fields would come from would be any footage that you have in your comp. but a small section of a screen grab would be helpful.
    also, are you seeing the fields when importing the render back into ae, or in other software? it is possible that since 1080 is typically interlaced, the software (including ae) may be interpreting it wrong. you can override ae’s interpretation in the interpret footage settings window.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
