Activity › Forums › Avid Media Composer › ProRes 422 (HQ) from FCP to AMA Transcode Out of Sync
  • ProRes 422 (HQ) from FCP to AMA Transcode Out of Sync
    Posted by Ricky Barrow on August 16, 2012 at 4:41 pm
    WE have Avid MC 6.0.3 on Win 7, 12GB RAM, Dual Hex-Core, 2.67ghz. Out of house tapes shot 720p 60 – shooter creates .mov ProRes 422 (HQ) through FCP. 5 tapes = 5 .mov files …. I now have 2 problems:
    1) QT on Win7 will play 3 files but will not recognize the other 2. On the MAC, all 5 files play. Thus, when AMA linking on Win7, Avid will only link to the 3 files that play in QT. On the MAC, where all 5 files play fine, QT Movie Inspector shows ALL files to be the same. Is this a glitch? Does it have something to do with FCP? Is QT and associated plugins different on MAC than on Win7? How can I correct this as it seems to be an on-going issue.
    2)Now .. of the 3 files that do play in QT Player on both platforms, QT Movie Inspector shows 59.94fps on 2 files and 59.84 on the 3rd file. They ALL play IN SYNC through QT Player, however, when AMA linking, this 1 file at 59.84fps during transcode of course wants to “convert frame rate” – the result is sync goes out quickly and isn’t even close near the end of the 30 minute video. Is there a way to correct this, in Avid or by converting the file before linking/transcoding? More importantly, is this a glitch in the capturing process through FCP? —- We had files from this shooter before where he transcoded to ProRes 422 (LT) – they seemed to work fine and that gives me a question, is his system handling a lower bitrate better than the higher bitrate as he captures and creates the files in realtime?
    So basically I am having trouble with fps on one file and not being able to read all files that seem identical according to QT Movie Inspector. Sometimes I miss just putting the 3/4 tape in the 3/4 machine and the Beta-SP tape in the Beta-SP machine!
    Thanks for any help.
    Ricky
    Ricky Barrow replied 14 years, 1 month ago 2 Members · 3 Replies
  • John Pale
    August 16, 2012 at 5:12 pm
    If you still have access to FCP 7, open the problem file in Cinema Tools and conform it to the proper frame rate…since it already is that frame rate, all it will really do is fix the corrupt metadata, and will take about a second. should work fine after that..hopefully.
  • Ricky Barrow
    August 16, 2012 at 5:21 pm
    Great, thank you John. Yes we have FCP 7 HD Studio on the MAC (although I know nothing about it – we have it mostly for these issues!) Ignorant question – what is Cinema Tools? is it part of FCP 7? Free download? TY!
    Ricky
  • Ricky Barrow
    August 16, 2012 at 5:31 pm
    Nevermind – TY, Found it.
    Ricky
