Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422 HQ
  • Posted by Jimmy Stewart on August 26, 2007 at 10:20 pm
    hello,
    i digitized footage from a dvd using the codec “ProRes 422 HQ.” it looks the best. i used fcp 6.0. however, i have 4.5 at home and the footage will not work. is there a way to get around this?
    thanks,
    j
    Sean Oneil replied 19 years, 1 month ago 4 Members · 3 Replies
  • Walter Biscardi
    August 26, 2007 at 10:22 pm
    [jimmy stewart] “however, i have 4.5 at home and the footage will not work. is there a way to get around this?”
    Not that I know of. ProRes only works in FCP 6.0 as far as I understand. You would have needed to use something like DV or 8bit Uncompressed to work on an older system.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Peter Dewit
    August 27, 2007 at 12:42 pm
    You could use the media manager tool and recompress those clips as something your older system will understand.
  • Sean Oneil
    August 27, 2007 at 2:52 pm
    You can copy the ProRes Quicktime components to your other system (/Library/Quicktime).
    This will let you read and write ProRes within any Quicktime based app. However, in FCP 4-5, you won’t get RT effects, and there may be other problems as well.
    Sean
