Activity › Forums › Apple Final Cut Pro Legacy › Prores 422>>> H.264
  • Prores 422>>> H.264
    Posted by Alaa Esmail on May 19, 2011 at 1:58 am
    Why when I try to export my project from prores 422 (LT) to H.264 The Quality And Size of video is smaller?
    the Frame is bigger than the actual video itself.
    for example. The title is in correct size, but the video itself is “shrunk”
    What Should I Do….?
    7D Dlsr Footage>>>Stream Clip>>>ProRes 422 (LT)>>>>FINAL Cut Pro>>>>Export Settings are
    Compressed H.264
    Frame size 1280 x 720
    Squared Pixels
    Alaa Esmail replied 15 years, 4 months ago 3 Members · 5 Replies
  • Sascha Engel
    May 19, 2011 at 5:32 am
    How do you export? Direct from FCP or through Compressor?
    Sascha
  • Chris Tompkins
    May 19, 2011 at 11:42 am
    H.264 is a delivery codec. It is highly compressed.
    ProRes is a high quality editing codec.
    Shoot hi quality.
    Edit Hi Quality.
    Export using “Current Settings”
    Drop that file into your compression program to make your deliverable.
    Chris Tompkins
    Video Atlanta LLC
  • Alaa Esmail
    May 19, 2011 at 3:17 pm
    Only FCP. I Will not be using compressor. I just need to know how to do It through FCP.
  • Sascha Engel
    May 19, 2011 at 4:16 pm
    That’s a pitty, because Compressor is easy to use, and the result are a lot better.
    I used to export also directly though FCP, but once I realized the difference in Q and Speed – I changed.
    It will take you 1-2 hours and you will know all you need – and those 2 hours are worth the invested time.
    Sascha
  • Alaa Esmail
    May 23, 2011 at 2:09 am
    The Point Is I Have No Other Choice Right Now But TO Use FCP….
