Activity Forums Apple Final Cut Pro Legacy ProRes 422 – 12 or more tracks of audio – constant rendering?
  • ProRes 422 – 12 or more tracks of audio – constant rendering?
    Posted by Tom Bh on May 3, 2012 at 9:14 am
    Hi
    As far as I know, my project is set up correctly. I don’t have to render audio or video edits, so I know my media is all the correct codec.
    However, when layered up, say 12 or more audio tracks, when ever a keyframe is edited that section requires rendering? Thoughts?
    Tom
    Tom Bh replied 14 years, 4 months ago 4 Members · 4 Replies
  • Rafael Amador
    May 3, 2012 at 1:18 pm
    Too many tracks.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    May 3, 2012 at 1:46 pm
    There’s preferences to set the number of real time audio tracks.
    The default might be 8, can’t remember off hand.
    If you have many filters on those tracks, it will require a render.
    If you have no filters, check your preferences.
    Jeremy
  • Shane Ross
    May 3, 2012 at 2:12 pm
    User settings…that’s where the Real Time audio tracks are. Yes, it defaults to 8. Set it to 32.
    Shane
    Little Frog Post
  • Tom Bh
    May 3, 2012 at 2:52 pm
    Perfect, that worked a charm! Thanks, Tom
