Activity Forums Adobe After Effects Expressions propertyIndex AND sourceText.split question
  • propertyIndex AND sourceText.split question
    Posted by Chris Scalzo on June 12, 2018 at 9:00 pm
    I wanted an expression on a text layer to mark #HASHTAGS and @SocialMediaNames blue. So I added the following code to the amount of color change in a bunch of Range selectors named 0, 1, 2…
    When I evalucate the value of x, it is the correct number, but this expression wouldn’t work unless I typed a number.
    I replaced
    y=text.sourceText.split(” “)[x][0];
    with
    y=text.sourceText.split(” “)[1][0];
    Also, if a gave it text that had two spaces, it through off the split from the value of the range selector.
    x=thisProperty.propertyGroup(1).propertyIndex-1;
    y=text.sourceText.split(" ")[x][0];
    if ((y == "#") || (y == "@")) 100 else 0
    Chris Scalzo replied 8 years, 2 months ago 1 Member · 1 Reply
  • Chris Scalzo
    June 18, 2018 at 7:16 pm
    I figured out what was wrong with my property index syntax. I am still looking for a solution to my text.split problem. will reword in a new post.
