Activity › Forums › Apple Final Cut Pro Legacy › properly formatting 2nd internal drive for fcp editing
  • properly formatting 2nd internal drive for fcp editing
    Posted by Lisa Rolley on October 29, 2008 at 5:22 pm
    I just got a Western Digital Sata drive (400GB) to install in my powermac G5 (dual 1.8ghz / 4BG RAM) in order to edit off of as opposed to the external lacie drives I had been using.
    The drive did have an image (OS) on it which i dont need so i want to put it in my tower use disk utility to erase and format it properly to be used as a 2nd internal drive for editing off of as I emtnioned.
    Can you knowledgeable guys explain to how best to set this drive up?
    thank you
    Lisa
    David Roth weiss replied 17 years, 11 months ago 2 Members · 3 Replies
  • David Roth weiss
    October 29, 2008 at 5:06 pm
    All drives on a Mac should be Mac Extended. Choose the not journaled option for Media drives.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Lisa Rolley
    October 29, 2008 at 5:28 pm
    thanks David you fast responder you!! you rock sir
    ok so i’ll just do extended then and reformat in disk utility correct?
    many thanks again
    best
    Lisa
  • David Roth weiss
    October 29, 2008 at 5:50 pm
    [lisa rolley] “i’ll just do extended then and reformat in disk utility correct?”
    Yes, that’s it…
    David Roth Weiss
    Director/Editor
    Los Angeles
