Activity Forums AJA Video Systems Proper way to capture 29.97 HD to 23.98p or 24P with Kona 3G
  • Proper way to capture 29.97 HD to 23.98p or 24P with Kona 3G
    Posted by Chris Borjis on July 21, 2014 at 5:42 pm
    long story short, I need to play out from a black magic decklink
    as HD 1080i 29.97, then capture that in another room to a Kona 3g
    as 1080P 23.98 or 24. (over hd-sdi)
    is that even do-able? I keep getting a split screen with
    a double image top and bottom when configuring the kona 3g
    from its control panel. And my broadcast monitor is freaking
    out instead of showing a stable image and indicating 48hz mode, (24 frame)
    which it is capable of (sony pvm-20/L5)
    Chris Borjis replied 12 years, 1 month ago 1 Member · 2 Replies
  • Chris Borjis
    July 21, 2014 at 6:55 pm
    disregard/never mind.
    I just dropped it in a 24P premiere cc sequence and it plays back perfect.
  • Chris Borjis
    August 1, 2014 at 5:39 pm
    update:
    Thought it was good but the Kona3G doesn’t do reverse pull-down,
    so it had to be ran through a Teranex.
