Activity Forums Apple Final Cut Pro Legacy Proper output of 2048×1152 RGB files to tape
  • Proper output of 2048×1152 RGB files to tape
    Posted by Eugene Lehnert on March 22, 2011 at 4:50 pm
    I have a 2048×1152 RGB file that I need to output to an HDCAM. Usually when I have 2048×1152 ProRes material the Kona 3 card does a straight downconvert to 1920×1080. But this RGB material is output at it’s native resolution pinned to the top left corner and I am getting a gamma shift. What are the proper settings for outputting this material to tape?
    Jeremy Garchow replied 15 years, 5 months ago 3 Members · 4 Replies
  • Gary Adcock
    March 22, 2011 at 5:41 pm
    [Eugene Lehnert] “I have a 2048×1152 RGB file that I need to output to an HDCAM.”
    HDCam does not support frames larger than 1920×1080.
    HDCamSR only supports beyond 1920 x1080 recording on the 5800 Series deck with a specific add on package.
    https://news.creativecow.net/story/859317
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Eugene Lehnert
    March 22, 2011 at 5:50 pm
    I understand. I’m trying to output 1920×1080. It seems to work if I turn the “mirror to desktop” button off.
    Thanks.
  • Eugene Lehnert
    March 22, 2011 at 8:03 pm
    Well it’s outputting but there is aliasing in the image. It looks like the Kona card is using an impulse like algorithm to downconvert the picture. When I render a section as ProRes 4444 instead of RGB the picture outputs ok. Odd. Contacting AJA.
  • Jeremy Garchow
    March 23, 2011 at 12:29 am
    Just curious, but why not nest your 2k in a 1080 YUV ProRes 422 HQ sequence? Why try and retain 2k/RGB when you’re going out to single link 1080 video tape?
    If that’s not feasible, it sounds like you might have the wrong 2k settings selected? There’s more than a few to choose from.
