Activity Forums Avid Media Composer Proper DNxHD Target Resolution for Pro Res Transcode?
  • Proper DNxHD Target Resolution for Pro Res Transcode?
    Posted by Ben Popik on October 13, 2011 at 3:45 am
    Hi all,
    I’m using Media Composer to transcode a Pro Res file (for my colorist, who works on an Avid system), and I’m not sure which is the best setting for the export:
    DNxHD 115
    DNxHD 175
    DNxHD 175 X
    I imagine that the bit rate of at least the top setting would be serious overkill.
    Thank you for your help!
    John Pale replied 14 years, 10 months ago 2 Members · 1 Reply
  • John Pale
    October 13, 2011 at 5:16 am
    Pro Res is 10 bit, so I would actually go with 175X, as its the only one of the three that is 10 bit.
