Activity Forums Adobe After Effects Proper composition settings to output to standard DVD
  • Proper composition settings to output to standard DVD
    Posted by Ed Moran on June 20, 2012 at 8:23 pm
    I want to eventually burn a widescreen dvd. What should my settings be?
    I know they talk about 480i and 480p but I am confused with the presets.
    Ed
    Tim Bentley replied 14 years, 3 months ago 2 Members · 1 Reply
  • Tim Bentley
    June 26, 2012 at 3:23 pm
    There’s really not enough information here – what software are you going to use to author (or simply build) the DVD? What’s the composition setup? Either way, I wouldn’t advise using After Effects to encode for a DVD – just render at the same settings as the original, and use a dedicated compression application.
    https://timbentley.info/films.html
