Activity › Forums › Adobe After Effects › Proper codec to bring After Effects footage into Final Cut Pro
  • Proper codec to bring After Effects footage into Final Cut Pro
    Posted by Andrew Marchand on October 12, 2011 at 9:57 pm
    I am working on After Effects on my Windows machine because it is faster than my Macbook. However, whenever I try to bring something over from After Effects into Final Cut, I seem unable to get the proper codec/file format.
    I was wondering if there was maybe something I could download or if there was a proper codec/way to render footage in order for it to be opened in Final Cut.
    Kevin Monahan replied 14 years, 11 months ago 3 Members · 2 Replies
  • Ben G unguren
    October 13, 2011 at 12:56 am
    [Andrew Marchand] ” I seem unable to get the proper codec/file format.”
    It would be helpful if you were more specific here. Is the image not showing up at all, or are you simply needing to render everything?
    In general, if you’re on a PC and want to send something to a Mac, you’ll want to install Quicktime player and render to a .mov using a Quicktime codec. The Animation codec is the most reliable codec (in my experience) but it isn’t for editing, so your editor will need to recompress it into whatever codec s/he is using for editing.
    Ideally you will be able to compress to the exact codec that’s being used for editing, but if it’s ProRes (for example) you won’t be able to do that. So if there isn’t a way to render to the exact codec you need, then render to .mov with the Animation codec.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Kevin Monahan
    October 13, 2011 at 9:28 pm
    That’s not exactly true. ProRes 4444 can carry the alpha channel. Just enable Millions of Colors + in the output. With Macs, I much prefer it over the Animation codec.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
