Activity Forums VEGAS Pro Projects Suddenly Render Black…Was Working Before
  • Projects Suddenly Render Black…Was Working Before
    Posted by Anthony Uccello on July 10, 2008 at 1:52 am
    No idea what I did, but I rendered a project just fine last night. Now when I try to render it again, the video is black.
    No matter what format I use now, the video renders as black. It is fine in the preview,but it suddenly stopped working after I render it.
    What did I mess up this time?:P
    Anthony Uccello replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    July 11, 2008 at 4:17 pm
    Can you give us some more details such as your project settings and your render template settings? Also, make sure you do not have your video track(s) muted and that you are not selecting in your render template to only encode audio.
    j razz
  • Anthony Uccello
    July 11, 2008 at 4:29 pm
    No idea what happened, no changes where made between one successful render to the next as far as I can tell…
    HOWEVER, I found a solution. I changed the frame rate from 29.997 to 30 (or higher) and it worked again. No idea why it works, but it does….
