Activity › Forums › Creative Community Conversations › Projects not scrubbing in the event
Charlie Austin replied 12 years, 9 months ago 5 Members · 39 Replies
Bret Williams
December 19, 2013 at 5:44 pmNot quite the same thing. If I wanted to see all the projects in all the Libraries in one place, I’d have to first change the grouping as you say, then select all the libraries. The iMovie thing is pretty novel. It’s sort of a smart collection of file type that lives outside the libraries.
Bret Williams
December 19, 2013 at 5:46 pmThe projects are still separate in the finder if you show package contents on an event. They’re there, just relegated to a different place. Really the media changes are pretty simple, but far reaching in their effect.
Charlie Austin
December 19, 2013 at 5:50 pm[Bret Williams] “The iMovie thing is pretty novel. It’s sort of a smart collection of file type that lives outside the libraries.”
Gotcha… well, like I said, iMovie more or less = FCP X now, so maybe something like it will appear… 🙂
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Jeremy Garchow
December 19, 2013 at 6:14 pmSo if you have multiple Events in a Library, how do you search keywords? Do you have to select multiple Events or can you search the Library?
Bret Williams
December 19, 2013 at 7:00 pmYou can search the library. In this aspect, as far as I can tell, the library is just a container. If you select it, it’s the same as shift clicking all the events contained within.
Charlie Austin
December 19, 2013 at 7:02 pm[Bret Williams] “You can search the library. In this aspect, as far as I can tell, the library is just a container.”
Libraries essentially function like mounted disks did in 10.0. So, yes, searchable etc…
Jeremy Garchow
December 19, 2013 at 7:04 pm[Bret Williams] ” If you select it, it’s the same as shift clicking all the events contained within.”
Hmm.
So if you are in a kw collection in an Event, the only other way to search another or all Event is to shift select what you want, or click the library.
And kw collections are Event specific and not attached to the library, right?
Charlie Austin
December 19, 2013 at 7:05 pm[Jeremy Garchow] “And kw collections are Event specific and not attached to the library, right?”
Yep, just as before…
Bret Williams
December 19, 2013 at 7:06 pmCorrect. I don’t see how this differers from past function. Does it?
Jeremy Garchow
December 19, 2013 at 7:06 pm[Charlie Austin] “Yep, just as before…”
So you can’t have an Eventless library with clips in it.
A Library HAS to have an Event.
