Activity › Forums › Creative Community Conversations › Projects not scrubbing in the event
Charlie Austin replied 12 years, 9 months ago 5 Members · 39 Replies
Bret Williams
December 19, 2013 at 9:58 pmAnd at least if the event gets corrupt, the projects are in a separate event. But naming it media just worked in this case because it was the only event except for one reserved for projects. It might be logical to have multiple events in a library, acting more like bins, but since key wording is tied to the event, it still seems illogical for my project based work.
Charlie Austin
December 19, 2013 at 9:58 pm[Mathieu Ghekiere] “I don’t know what I’m supposed to see on your picture (I can view the picture but I think I’m missing something?)
But are you saying you can put Projects into Keyword collections now?”Yep, all those collections in the “CUTS” Event have 5 or more versions of each project. Works quite well, and if you’ve got your stuff in folders in the old Project Library, it converts them to Keyword Collections when u update. 🙂
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Bill Davis
December 19, 2013 at 10:12 pm[Bret Williams] “They’re definitely trying to discourage messing around in the finder by making the library a launchable document. “
“Messing around” yes, absolutely.
But I was interested to read in the Apple White Paper – that now that we have Libraries, Apple officially supports doing finder copies of entire Libraries in X.
So at least having all the assets consolidated into a top level structure means those on centralized storage systems can move things around more easily.
In the new structure, we’re all going to have to spend some time wrapping our brains around how the new types of references assets work I suspect. But at least Libraries mean that there s a single top level container that will help in collaborative workflows.
I am sad to lose my beloved laid out Project Libraries – but I’m trusting that with this loss will come new possibilities.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Jeremy Garchow
December 19, 2013 at 10:38 pm[Charlie Austin] “You can, but I’d suggest extreme caution… As before, shuffling things at the Finder level can have unexpected consequences. I’d imagine more so now that everythings in a package
“Right, but not in the Project LIbrary.
The Project Library simply mirrored what was in the Final Cut Projects folder.
I organize Projects a lot in the Finder as you can’t select more than one Project in FCPX 10.0.9.
Sheesh, I can’t wait till I an update and give this thing a whirl.
Mathieu Ghekiere
December 19, 2013 at 10:49 pmThanks, Charlie.
That’s more or less logical, helps in the new structure.
Charlie Austin
December 19, 2013 at 10:52 pm[Jeremy Garchow] “I organize Projects a lot in the Finder as you can’t select more than one Project in FCPX 10.0.9.
“Well, you can now. You can also delete render files from multiple selected Projects and/or Events. In a way it’s easier than FCP7’s Render Manager. And by in a way, i mean it is. 🙂
Charlie Austin
December 19, 2013 at 10:56 pm[Mathieu Ghekiere] “Thanks, Charlie.
That’s more or less logical, helps in the new structure.”
My pleasure. There’s some more random, hopefully helpful info in the post that pic came from.
Jeremy Garchow
December 19, 2013 at 11:00 pm[Charlie Austin] “Well, you can now. You can also delete render files from multiple selected Projects and/or Events. In a way it’s easier than FCP7’s Render Manager. And by in a way, i mean it is. :-)”
Good to know. That bothers me to no end in 10.0.9
Charlie Austin
December 20, 2013 at 7:35 am[James Ewart] “For the life of me I cannot tell the difference between a Library and an Event”
Remember in the olden days (10.0.x) you’d have mounted drives in the Event Library, and there were Events on each drive? Well, think of Libraries as just taking the place of those drives. Except instead of needing to mount drives to open the Events on them, you just open the Library. And the projects live in the same place. Other than that, Events and Projects are pretty much the same-ish. 🙂
