Projects and Events don’t show up in FCPX although hard drive shows up
Hi Guys
So here’s the deal, I have been working on a certain project in fcpx, then took a break for a couple of days. During that time, I put some projects and events from another hard drive into the already existing Final Cut Projects and Final Cut Events folders (they are at root level btw). After that, none of the projects and events show up in fcpx, although the drive does.
I tried to look for files that could have made the hard drive look like a camera to fcpx (avchd, dcim) and there weren’t any. Are there maybe other files that could do that? I work with dslr footage.
I deleted the projects and events I added and the original project I was working on still doesn’t show up. I’m not sure where to go from here…
Oh, and one more thing, I switched between working on the 10.0.8 version of fcpx and 10.0.9 version while working on that first project. Do you think that would have screwed something up? Even if it did, I feel like something would show up right? Plus I have done that before and there haven’t been issues.
I’m currently using 10.0.8. I’d appreciate any help, thanks!
Jasmine
