Activity Forums Apple Final Cut Pro Legacy Projection Strategy, DVCPRO HD Original
  • Projection Strategy, DVCPRO HD Original
    Posted by Tareco Pictures on September 13, 2006 at 11:16 pm
    Our indie feature was posted in FCP 5.0.4 on DVCPRO HD @ 23.98 1080i60 (original footage 23.98 HDCAM). A QT export with current quality settings is 62GB. We are soon to project it in a 400-seat local theatre with in-house Proxima 9310 projector with these specs:
    Resolution-
    XGA 1024×768
    Resolutions Supported:
    VGA (640 x 480, Fit-to-View)
    SVGA (800 x 600, Fit-to-View)
    XGA (1024 x 768)
    SXGA (1280 x 1024, Fit-to-View) wide format (16:9 aspect) capable
    Computer Input: R-G-B-H-V, HD-15
    Video Input: Component, S-Video, Composite
    We tested a well-encoded DVD on site via S-video and it looked passable, so for the big night we’ll use a component-out DVD player. But, wouldn’t it be great to use the projector’s maximum quality? So does anyone know what type of signal / data to feed this Proxima to take advantage of what its specs call “SXGA (1280 x 1024, Fit-to-View) wide format (16:9 aspect) capable” functionality? Its manual does not explain “Fit-to-View”; no luck with response from Proxima support for further explanation.
    What playback device appropriate for this projector would yield better, less-compressed image quality than simply a component-out DVD player? At this time we can’t afford to rent an HD-capable projector and HDCAM player, so this Proxima is our current challenge.
    Caveat: if a solution involves bringing our G5 tower to the theatre, the system from our edit room cannot travel. Our screening is in 10 days. Thanks for any ideas!
    Bill
    FCP 5.0.4 w/ Kona 2
    Power Mac G5 Dual 2.5, 4GB RAM, OS 10.4.4
    ADTX RAID, ATTO Celerity FC-22XH, Misc. LaCie FW Drives
    Tareco Pictures replied 20 years ago 3 Members · 3 Replies
  • David Roth weiss
    September 14, 2006 at 3:12 am
    Can you borrow a laptop?
  • Jeremy Garchow
    September 14, 2006 at 6:07 am
    Got any laptops?
  • Tareco Pictures
    September 14, 2006 at 6:19 am
    Thanks for the responses! We have only a 3-year old G4 1ghz PowerBook w/ 1GB RAM.
    If I could get a more juiced laptop, what type of movie file at what aspect ratio could feed that projector’s “SXGA (1280 x 1024, Fit-to-View) wide format (16:9 aspect) capable” resolution?
    If that particular resolution setup is somehow hinky, then what is the most reliable movie file format that will look better than DVD, and run reliably?
    Bill
