Activity Forums Maxon Cinema 4D Projection Man Textures not visible in viewport
  • Projection Man Textures not visible in viewport
    Posted by Jeremiah Belt on April 3, 2015 at 7:42 pm
    First time using Projection Man in C4D. Got it all setup correctly using a tutorial. Everything works and I can render the scene and see the projected texture on the object. However I cannot see the texture on the object in the viewport. The object just disappears when assigned the texture. This obviously makes it impossible to work with. How can I fix this and see the texture in the viewport?
    Jeremiah Belt replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
