Activity › Forums › Maxon Cinema 4D › Projecting video into a c4d scene
Posted by Paul Rijkaard on January 15, 2016 at 1:04 pmis it possible in c4d to project video rather than it attaching it to an object surface? I mean specifically to recreate the effect of placing a projector into a room and shining it onto objects, so that the objects are illuminated by the video? and so that the video image distorts with the shape of the object it is beaming onto.
Many thanks
Paul
Adam Trachtenberg replied 10 years, 8 months ago 4 Members · 6 Replies -
Jack Cook
January 15, 2016 at 1:28 pmYou might be able to do that by using a spot light as a projector and putting the movie into the transparency channel of a material, then putting the material on the light as a gel. In the transparency channel you then need to click on the button to edit the movie, then click on the Animation tab and click Calculate.
Jack
Luka Schulz
January 15, 2016 at 2:01 pmIm not sure if that will accomplish what I am hoping to do. I only want the edges textured.
Paul Rijkaard
January 15, 2016 at 2:16 pmAmazing, thank you very helpful.
At the moment I can see that there is an animation there, but it is relatively much bigger than the light beam, do you know how I would go about scaling the animation in the transparency channel?Also could you give an indicator about how I might square off the spotlight shape so that it is not round?
Many thanks
Adam Trachtenberg
January 15, 2016 at 3:07 pmYou can adjust the size and aspect ratio of the beam by scaling the UVs of the light/material.
Paul Rijkaard
January 15, 2016 at 3:08 pmI think I have figured how to resize by changing the scale of the material tag applied to the light,
but have found a slightly odd thing: I want a single projection of the video – as default the material tag is set to tile – when I switch this off the image disappears. Any ideas why?
Adam Trachtenberg
January 15, 2016 at 6:40 pmSelect your light and the texture tag and then enable the Texture Tool. Assuming that your tag is set to use flat projection you should see a yellow grid which represents the projection. You can use the move, scale, and rotate tools to place the projection exactly where you want it.
