project window with project preview window
Posted by Doyal Gudgel on April 27, 2011 at 11:53 pmRight now my project preview window extends completely across the screen. I need a portion of it to display project media or perhaps other information at the sae time. How can I arrange it? I could put up a screen shot if necessary but I think this will explain it ok.
When I bought the program that was the way it came I believe
ThanksThe graveyards are full of people the world couldn’t do without
Doyal Gudgel replied 15 years, 4 months ago 2 Members · 15 Replies -
Mike Kujbida
April 28, 2011 at 1:34 pm -
Doyal Gudgel
May 1, 2011 at 6:00 pmSomething seems to have changed here and the easiest tway to do this is have you go to a blog to see why I cant do it your way. I would like the vegas window to display the things the way yours is displayed. Is there a default window? Please check it out here. temporaryposts.blogspot.com I am slow to answer because I didn’t get your answer.
Doyal Gudgel
May 1, 2011 at 11:42 pmLet me try to explain my problem so it is understandable. I want to look at the preview window for the trimmer while I edit in the trimmer time line. I suppose there is one for the trimmer time line. You can see my current window configuration as it is now by going to temporaryposts.blogspot.com I went through the complete steps in the tutorial(again) which created a different configuration. I can see the preview window for the project timeline so I assume there is one for the trimmer timeline. I’m almost there and all I need is a little nudge to get this problem understood.
Mike Kujbida
May 2, 2011 at 12:22 am -
Doyal Gudgel
May 2, 2011 at 12:37 amIs the upper picture the trimmer window and the lower string the trimmer timeline? If I were to put the cursor on the bottom time line where it is should show in the upper picture? My problem I can only see one or the other but not both at the same time. How do you get this configuration? I also have to find instructions for posting direct to the forum.
Mike Kujbida
May 2, 2011 at 12:44 amThe picture in the top left is the Trimmer window, top right is the Preview window and the Vegas timeline is the bottom half of the screen.
You can enable/disable anything you want in the View menu.
View – Window Layouts – Default Layout (on Vegas Pro) to get back to square one. -
Doyal Gudgel
May 2, 2011 at 3:47 am -
Doyal Gudgel
May 2, 2011 at 3:49 amThanks
DI think I did something wrong but it did go to the blog with the picture which does the same thing
Doyal Gudgel
May 2, 2011 at 4:20 amCheck this out if you can. Please take a look. I did something wrong last time I think.
Doyal Gudgel
May 2, 2011 at 4:23 amI’ll try more tomorrow I am tired now. All for today
