Activity › Forums › Apple Final Cut Pro Legacy › PROJECT UNREADABLE
  • PROJECT UNREADABLE
    Posted by Randolph Harrison on May 13, 2007 at 8:43 pm
    Frustrated! I have a full-length feature project, which I’ve just finished loading all of the media onto drives, and have just organized my bins. During the loading process on occasion, and several days in a row afterwards, when launching FCP 5.1.2, a window reads, “This project is unreadable or may be too new for this version of Final Cut”.
    Sometimes, merely rebooting drives and computer has fixed the problem and it would open. Other times I would throw away user data & plist and it might open. And again other times I would open from the auto save vault, rename it to the project name and it would fix the problem.
    The last three days, none of these fixes worked. After renaming the backup, throwing away prefs, etc, it might open the project once but the next day, I would get the same window.
    When I would get these at the very first, I even deleted all the media (2.5 terabytes), reformatted the drive, and reloaded the media.
    My system: Power PC G5 quad 2.5, 4.5 gigs ram, Tiger 10.4.8, FCP 5.1.2, L2 cache per cpu 1mb, bus speed 1.25, GeForce 6600, 20″ Cinema Display & 23″ Cinema Display.
    Drives, currently 3 – LaCie 1 Terrabyte. (I have even run the material on a sata system 10X500mg Seagates with the same results)
    Media- P2, 1080 24p. Imported with “Remove advanced pulldown and duplicate frames” turned OFF. Project is DVCPRO HD 1080i60, Sequence preset DVCPRO HD 1080P24.
    Is this a “bug” inherent to 5.1.2? Since we have just begun the project only one sequence started, would it be advisable to upgrade to 5.1.4? Or is this user error?
    It is very important for me to figure this out because another editor is helping me on another system. The projects are named the same, the drives are cloned identically.
    I would appreciate any insight and help.
    Thank you in advance,
    Randy Harrison
    Steven Lambion replied 19 years, 4 months ago 2 Members · 1 Reply
  • Steven Lambion
    May 14, 2007 at 10:08 pm
    Well all I can say is try it in a different user account or a different machine. If this works then it sounds like you need to either reinstall the software or OS, or change user accounts for the project. Best of Luck!!
    Video Specialist
    Apple Developer
    Owner of GranitWorks
