Activity Forums Adobe Premiere Pro Project transfer between hard drives
  • Project transfer between hard drives
    Posted by Sean O’dea on June 29, 2007 at 1:23 pm
    Hello and thanks in advance for any advice.
    I have an hour long video project, heavy on the rendering, that needs to be re-edited.
    When I first finished it, I simply copied everything and pasted on an external hard drive.
    I’ve since transferred it back to the internal hard drive on the computer I’m editing with.
    When I open the project, PP 2.0 keeps asking me to relink the media and while it seems to find the render files too, the entire project has to be re-rendered, which is awfully inconvenient.
    Am I doing something wrong here?
    Vince Becquiot replied 19 years, 3 months ago 2 Members · 3 Replies
  • Vince Becquiot
    June 29, 2007 at 1:55 pm
    Rendered files or “preview files’ are usually saved in a separate folder, as specified in your scratch disk preferences. You will probably have to render again.
    Next time you leave a project alone for a while , you should use the Project Manager (Project > Project manager) . This will allow you to consolidate all your project files in one folder, as well as include your audio and video previews.
    Cheers,
    Vince
  • Sean O’dea
    June 29, 2007 at 1:59 pm
    Thanks for the info.
    I think I did actually use the project manager when archiving the original project (it’s been a year or so ago and i edit every blue moon or so).
    I used the “trim” function to consolidate it. Is this not the same thing?
  • Vince Becquiot
    June 29, 2007 at 4:07 pm
    There is a “remove unused” function in the project menu, and that’s all it does.
    The project manager will allow you to copy everything to a new folder, and you can check an option to keep the preview files as well.
    Vince
