Activity › Forums › Apple Final Cut Pro Legacy › project takes to long to open :(
  • project takes to long to open :(
    Posted by Zeliha Bozkurt on June 5, 2006 at 10:30 am
    Happy Monday Everybody
    My project is taking too long to open and sometise I get the beech ball and have to re-start the computer. 🙁
    I trashed the preferences but this didn’t help.
    I read somewhere that you should never fill more thatn 85 % of a drive. According to my poor maths I have exceeded this limit.
    Size of the project is: 158mb
    I have 2 external drives Raid 1 & Raid 2
    Most my footage is on Raid 1 and its capacity is 1.27TB, available space left is 57 GB.
    Do I need to move some of my footage onto the second drive would this improve things.
    Any advice on this issue is much appericiated.
    Zee. 🙂
    Kevin Monahan replied 20 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Eisen
    June 5, 2006 at 11:48 am
    That is very normal for your project size. You have to be very patient. The project will open eventually. It could take 5 minutes or more to open.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Walter Biscardi
    June 5, 2006 at 12:47 pm
    Definitely normal for a project your size and with that much media. The issue with filling your drives affects playback performance, not the opening of the project. The more you fill your drives past 75 – 80% full, the more likely you are to get dropped frames.
    In fact, if you move some of the media off to a third drive, it will take even longer for the project to open. You want your media on as few drives as possible.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Zeliha Bozkurt
    June 5, 2006 at 2:38 pm
    Thank you for your reply
    Actually now the programme isn’t running so smothly and as you stated it is dropping frames and taking much longer to do things. If moving the media onto a second drive will help run FCP smoothly I don’t mind that the project will take longer to open.
    I think I will move 10 gig of my media onto the second drive, is that enough amount to move?
    Zee
  • Steven Gonzales
    June 5, 2006 at 3:00 pm
    “Most my footage is on Raid 1 and its capacity is 1.27TB, available space left is 57 GB.”
    If you have 1.27 TB, that’s 1,270 megabytes. If you want 20% free space, you would need to have 254 gb free space. You have 57 gb free space, so you should move 197 gb.
    You can also break up your project file into smaller projects. You could make a duplicate, and in the new duplicate delete all your old sequences, leaving only those you are currently working on. You should see a much small project that will open faster. You can always open the older project if you need anything in it, but your day to day work would be in a smaller project.
  • John Pale
    Another thing to keep in mind…unlike Avid, you can open more than one project at a time….therefore you can move bins, clips and sequences that are not needed frequently into other projects to reduce the size of your working project. Just open the other project(s) when you need them.
  • Steven Gonzales
    June 5, 2006 at 3:02 pm
    Sorry, I mis-typed, 1.27 terabytes is 1,270 gigabytes.
  • Kevin Monahan
    June 5, 2006 at 6:03 pm
