Activity Forums Apple Final Cut Pro Legacy Project suddenly crashing FCP & Motion.
  • Project suddenly crashing FCP & Motion.
    Posted by Alex Bluffield on January 21, 2010 at 2:52 pm
    My FCP project that was fine 3 weeks & haven’t touched since is suddenly crashing FCP and also Motion when I try and open Motion files from the project. I’m running Snow Leopard 10.6.2 and FCP 7.01, Motion 4 – it seems to be something to do with the openzone framework – I’ve read old posts on the issue but nothing related to Snow Leopard or FCP 7. I removed FCS with FCS remover and did a fresh install, but still crashing. Full error message below:
    Process: Final Cut Pro [2282]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 7.0.1 (7.0.1)
    Build Info: FCPApp-910141802~4
    Code Type: X86 (Native)
    Parent Process: launchd [120]
    Date/Time: 2010-01-21 14:43:51.132 +0000
    OS Version: Mac OS X 10.6.2 (10C540)
    Report Version: 6
    Interval Since Last Report: 353022 sec
    Crashes Since Last Report: 18
    Per-App Interval Since Last Report: 40805 sec
    Per-App Crashes Since Last Report: 12
    Anonymous UUID: F2F27A55-8927-4B8B-A5FC-CBE407CF88CD
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000006
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 com.apple.motion.TextFramework 0x23c02248 TXTextLayout::doATSULayout(unsigned int, double, OZRenderState const&) + 1960
    1 com.apple.motion.TextFramework 0x23c0abd8 TXTextLayout::doLayout(OZRenderState const&, PCHash128*) + 2936
    2 com.apple.motion.TextFramework 0x23c0aebe TXTextLayout::buildRenderGraph(OZRenderParams&, LiGraphBuilder*, OZRenderGraphState const&) + 286
    3 com.apple.ozone.framework 0x22701c79 OZGroup::makeRenderGraphOfElements(OZRenderParams&, LiGraphBuilder*, OZRenderGraphState const&, bool) + 1609
    4 com.apple.ozone.framework 0x227054f8 OZGroup::buildRenderGraph(OZRenderParams&, LiGraphBuilder*, OZRenderGraphState const&) + 232
    5 com.apple.ozone.framework 0x22663df5 OZScene::buildRenderGraph(OZRenderParams&) + 2165
    6 com.apple.ozone.framework 0x228c9954 GLRenderer::getFrameNodeForSingleTime(OZScene*, OZRenderParams&, HGRenderer*, double, double, long*) + 1508
    7 com.apple.ozone.framework 0x228ca008 GLRenderer::getFrameNodeIncludingFields(OZScene*, OZRenderParams&, HGRenderer*, long*) + 312
    8 com.apple.ozone.framework 0x228ca894 GLRenderer::getFrameNode(OZScene*, OZRenderParams&, HGRenderer*, long*) + 164
    9 com.apple.ozone.framework 0x228ce817 GLRenderer::render(OZScene*, OZRenderParams&) + 2583
    10 com.apple.ozone.framework 0x2296fdd3 OZXGetFrame + 2755
    11 com.apple.ozone.framework 0x22972466 OZXGetFrameAsBitmap + 86
    12 com.apple.motion.component 0x0b5b4e09 0xb5b3000 + 7689
    13 …ple.CoreServices.CarbonCore 0x973da474 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    14 com.apple.motion.component 0x0b5b562a OZQTCodecComponentDispatch + 202
    15 …ple.CoreServices.CarbonCore 0x973d2b06 CallComponentDispatch + 29
    16 …ickTimeComponents.component 0x93f8d310 ImageCodecDrawBand + 43
    17 …ickTimeComponents.component 0x938d12be BaseCodec_DecompressWorkFunction + 1002
    18 …ickTimeComponents.component 0x938d1a40 BaseCodec_DecompressCallBack_Common + 1328
    19 …ickTimeComponents.component 0x938d371a Base_CDBandDecompress + 5449
    20 …ple.CoreServices.CarbonCore 0x973da474 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    21 …ickTimeComponents.component 0x938ceb9b Base_CDComponentDispatch + 127
    22 …ple.CoreServices.CarbonCore 0x973d2b06 CallComponentDispatch + 29
    23 com.apple.QuickTime 0x90d28a0c ImageCodecBandDecompress + 43
    24 com.apple.QuickTime 0x90d16b00 DoBandedDecompress + 17559
    25 com.apple.QuickTime 0x90d1246d ICMAction + 1177
    26 com.apple.QuickTime 0x90d1107c ICMDeviceLoop + 546
    27 com.apple.QuickTime 0x90d1a00a DecompressSequenceFrameWhen + 714
    28 …ickTimeComponents.component 0x937bf940 v2m_rDecompressSequenceFrameWhen + 1092
    29 …ickTimeComponents.component 0x937c2bf2 v2m_decompressVideoFrame + 609
    30 …ickTimeComponents.component 0x937c6781 QueueAFrame + 1595
    31 …ickTimeComponents.component 0x937c7681 v2m_doWhatTheMentorTellsUs + 1243
    32 …ickTimeComponents.component 0x937caf27 Video2MoviesTask + 2891
    33 …ple.CoreServices.CarbonCore 0x973e572d callComponentStorage_44444 + 49
    34 …ple.CoreServices.CarbonCore 0x973da474 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    35 …ickTimeComponents.component 0x937b8411 Video2ComponentDispatch + 212
    36 …ple.CoreServices.CarbonCore 0x973d2b06 CallComponentDispatch + 29
    37 com.apple.QuickTime 0x90d6c083 MediaMoviesTask + 61
    38 com.apple.QuickTime 0x90d6ae33 TaskMovie_priv + 4783
    39 com.apple.QuickTime 0x90d7db68 MoviesTask_priv + 101
    40 …alCutPro.Plugins.QTM Reader 0x0ac6ed45 LongGOPChunkWriter::receiveSample(unsigned char const*, long long, unsigned long, long long, long long, SampleDescription**, unsigned long, unsigned long, long long, bool) + 21955
    41 …alCutPro.Plugins.QTM Reader 0x0ac7f095 PluginMainEntry(long, long, KGDictInt*, void*) + 7555
    42 com.apple.FinalCutPro 0x00246043 pKGGetFileVideo(KGDictInt*, double, long, unsigned char, KGCanvasRec*, KGRect*, KGDictInt*, KGFileRec*, unsigned long long, long) + 1615
    43 com.apple.FinalCutPro 0x0024d9de GetItemFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 728
    44 com.apple.FinalCutPro 0x0024f2a6 GetSpeedFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 3556
    45 com.apple.FinalCutPro 0x0024f427 GetFilterFrame(KGDictInt*, KGClipItemType, long, unsigned char, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 359
    46 com.apple.FinalCutPro 0x00254789 GetMotionFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 11215
    47 com.apple.FinalCutPro 0x00255207 GetBlurFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 2627
    48 com.apple.FinalCutPro 0x00256777 GetTrackItemFrame(KGDictInt*, TrackInfoRec*, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 5473
    49 com.apple.FinalCutPro 0x0024c924 CompositeLoop(KGDictInt*, WhenRec*, KGCanvasRec*, KGRect*, BufferInfoRec*, renderStackInfo*, unsigned char*, TrackItemAtTimeCache*) + 1704
    50 com.apple.FinalCutPro 0x00258182 pKGGetClipVideoWithAlpha(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 5408
    51 com.apple.FinalCutPro 0x0024b6a9 pKGGetClipVideoWithAlphaMulticlip(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 281
    52 com.apple.FinalCutPro 0x0045d90a GetVideoFromRenderEngine(XXGlobals*, Output*) + 878
    53 com.apple.FinalCutPro 0x004616d2 DecodePipeTree(XXGlobals*, Output*) + 184
    54 com.apple.FinalCutPro 0x0042bb15 FCPMediaHandler::RenderFrames(long long, bool) + 3981
    55 com.apple.FinalCutPro 0x0042c17b FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 657
    56 com.apple.FinalCutPro 0x0042d245 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 45
    57 …ple.CoreServices.CarbonCore 0x973e572d callComponentStorage_44444 + 49
    58 …ple.CoreServices.CarbonCore 0x973da474 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    59 com.apple.FinalCutPro 0x00426009 FCPMHDispatch(ComponentParameters*, char**) + 59
    60 …ple.CoreServices.CarbonCore 0x973d2b06 CallComponentDispatch + 29
    61 …ickTimeComponents.component 0x93f89de7 MediaIdle + 61
    62 …ickTimeComponents.component 0x9380c3b6 doGenericIdle + 2991
    63 …ickTimeComponents.component 0x9380e1eb GenericMoviesTask + 357
    64 …ple.CoreServices.CarbonCore 0x973e572d callComponentStorage_44444 + 49
    65 …ple.CoreServices.CarbonCore 0x973da474 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    66 …ickTimeComponents.component 0x9380d93e GenericComponentDispatch + 182
    67 com.apple.FinalCutPro 0x00426025 FCPMHDispatch(ComponentParameters*, char**) + 87
    68 …ple.CoreServices.CarbonCore 0x973d2b06 CallComponentDispatch + 29
    69 com.apple.QuickTime 0x90d6c083 MediaMoviesTask + 61
    70 com.apple.QuickTime 0x90d6ae33 TaskMovie_priv + 4783
    71 com.apple.QuickTime 0x90d7db68 MoviesTask_priv + 101
    72 com.apple.FinalCutPro 0x001bad50 DoMoviesTask(KGPlayerRec*) + 2388
    73 com.apple.FinalCutPro 0x001cda79 DisplayMovie(KGPlayerRec*) + 2201
    74 com.apple.FinalCutPro 0x001d2827 pKGPlayerGoto(KGPlayerRec*, double, long, unsigned char) + 509
    75 com.apple.FinalCutPro 0x001bb59b PlayerNotify(long, long, KGDictInt*, void*) + 149
    76 com.apple.FinalCutPro 0x001142d1 DispatchNotificationsHelp(void**, KGDictInt*, long, long, unsigned char) + 157
    77 com.apple.FinalCutPro 0x001145c5 DispatchNotifications + 273
    78 com.apple.FinalCutPro 0x0001ea7f HashInsertFull(HashDict*, char*, long, unsigned char, void*, KGTypeValueContainer*, void**, unsigned char, KGDictNotifyHolder**, KGDictUndoMethod, long, unsigned char, unsigned long) + 1083
    79 com.apple.FinalCutPro 0x00020131 DispatchHashDict(KGDictSelector, KGDictInt*, KGDictParams*) + 221
    80 com.apple.FinalCutPro 0x00115320 pKGDictPut1(KGDictInt*, void*, long, char*) + 88
    81 com.apple.FinalCutPro 0x0010751d pKGRulerMessage(long, long, KGDictInt*, KGViewRecord*) + 14071
    82 com.apple.FinalCutPro 0x002a8161 PPassMouseEvent(KGPanelRecord*, KGDictInt*, long) + 1537
    83 com.apple.FinalCutPro 0x002b1428 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 78
    84 com.apple.FinalCutPro 0x0025e99e ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120
    85 com.apple.FinalCutPro 0x0025fe48 TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 110
    86 com.apple.FinalCutPro 0x002a78b1 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
    87 com.apple.FinalCutPro 0x002bd6d3 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 91
    88 com.apple.FinalCutPro 0x001572c2 HandleMouseDown(OpaqueEventRef*) + 1190
    89 com.apple.FinalCutPro 0x0015824b DoEvent(OpaqueEventRef*, KGDictInt*) + 729
    90 com.apple.FinalCutPro 0x0041436d Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 67
    91 com.apple.HIToolbox 0x96049e29 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
    92 com.apple.HIToolbox 0x960490f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    93 com.apple.HIToolbox 0x9606b981 SendEventToEventTarget + 52
    94 com.apple.HIToolbox 0x9607d457 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257
    95 com.apple.HIToolbox 0x9604a27a DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
    96 com.apple.HIToolbox 0x960490f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    97 com.apple.HIToolbox 0x9606b981 SendEventToEventTarget + 52
    98 com.apple.HIToolbox 0x961f481b ToolboxEventDispatcher + 86
    99 com.apple.HIToolbox 0x961f4953 RunApplicationEventLoop + 243
    100 com.apple.FinalCutPro 0x00153f23 KGMainEvent(void*) + 51
    101 com.apple.FinalCutPro 0x002c13a8 main + 54
    102 com.apple.FinalCutPro 0x0000333b _start + 209
    103 com.apple.FinalCutPro 0x00003269 start + 41
    Thread 1: Dispatch queue: com.apple.libdispatch-manager
    0 libSystem.B.dylib 0x98d5a0ea kevent + 10
    1 libSystem.B.dylib 0x98d5a804 _dispatch_mgr_invoke + 215
    2 libSystem.B.dylib 0x98d59cc3 _dispatch_queue_invoke + 163
    3 libSystem.B.dylib 0x98d59a68 _dispatch_worker_thread2 + 234
    4 libSystem.B.dylib 0x98d594f1 _pthread_wqthread + 390
    5 libSystem.B.dylib 0x98d59336 start_wqthread + 30
    Thread 2:
    0 libSystem.B.dylib 0x98d52856 select$DARWIN_EXTSN + 10
    1 com.apple.CoreFoundation 0x958b8ddd __CFSocketManager + 1085
    2 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    3 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 3:
    0 libSystem.B.dylib 0x98d33922 semaphore_wait_signal_trap + 10
    1 libSystem.B.dylib 0x98d6145c _pthread_cond_wait + 1089
    2 libSystem.B.dylib 0x98daa503 pthread_cond_wait + 48
    3 com.apple.FinalCutPro 0x0043e8b5 Synchronizable::Wait() + 53
    4 com.apple.FinalCutPro 0x00428ecf DisplayQueue::Run() + 681
    5 com.apple.FinalCutPro 0x0046a642 Thread::RunHelper(void*) + 20
    6 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    7 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 4:
    4 com.apple.FinalCutPro 0x004e5481 WorkUnitPerformer::Run() + 55
    Thread 5:
    0 libSystem.B.dylib 0x98d338da mach_msg_trap + 10
    1 libSystem.B.dylib 0x98d34047 mach_msg + 68
    2 com.apple.CoreFoundation 0x9587977f __CFRunLoopRun + 2079
    3 com.apple.CoreFoundation 0x95878864 CFRunLoopRunSpecific + 452
    4 com.apple.CoreFoundation 0x9587e7a4 CFRunLoopRun + 84
    5 com.apple.DVCPROHDMuxer 0x2239698f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
    Thread 6:
    4 com.apple.CoreFoundation 0x95878691 CFRunLoopRunInMode + 97
    5 ….CoreMediaIOServicesPrivate 0x01025a3b MIO::DAL::RunLoop::OwnThread(void*) + 157
    6 ….CoreMediaIOServicesPrivate 0x010278ac CAPThread::Entry(CAPThread*) + 96
    7 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    8 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 7:
    5 com.apple.qmaster.do 0x3443b3b2 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
    6 com.apple.AECore 0x24cf3092 aecore::CThread::runThread() + 34
    7 com.apple.AECore 0x24cf1029 threadProc(void*) + 17
    8 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    9 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 8:
    1 com.apple.AECore 0x24cf30d7 aecore::CThread::runThread() + 103
    2 com.apple.AECore 0x24cf1029 threadProc(void*) + 17
    3 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    4 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 9:
    0 libSystem.B.dylib 0x98d3393a semaphore_timedwait_signal_trap + 10
    1 libSystem.B.dylib 0x98d61445 _pthread_cond_wait + 1066
    2 libSystem.B.dylib 0x98d90028 pthread_cond_timedwait_relative_np + 47
    3 …ple.CoreServices.CarbonCore 0x973b2235 TSWaitOnConditionTimedRelative + 242
    4 …ple.CoreServices.CarbonCore 0x973b1f73 TSWaitOnSemaphoreCommon + 511
    5 …ickTimeComponents.component 0x937a2035 ReadSchedulerThreadEntryPoint + 4698
    Thread 10:
    5 com.apple.DesktopServices 0x94a3b63f TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
    6 …ple.CoreServices.CarbonCore 0x973917ae PrivateMPEntryPoint + 68
    Thread 11:
    0 libSystem.B.dylib 0x98d61806 __semwait_signal + 10
    1 libSystem.B.dylib 0x98d614c2 _pthread_cond_wait + 1191
    2 libSystem.B.dylib 0x98d63158 pthread_cond_wait$UNIX2003 + 73
    3 com.apple.ozone.framework 0x2290621b OZExecutionUnit::executeLoop() + 75
    4 com.apple.ozone.framework 0x2290631e OZExecutionUnit::executeLoopWrapper(void*) + 94
    5 com.apple.procore.framework 0x0b7af76c PCThread::startup(void*) + 18
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    5 …ple.CoreServices.CarbonCore 0x9740c508 AIOFileThread(void*) + 1127
    Thread 18:
    3 com.apple.AppleVADriver 0x4334e32c AVAGetRendererInfo + 7580
    4 com.apple.AppleVADriver 0x43353c1f AVAGetRendererInfo + 30351
    5 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    6 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 19:
    Thread 20:
    3 com.apple.vImage 0x95d8350c vImageQueue_DequeueJob + 44
    4 com.apple.vImage 0x95d8360c vImageWorkerThreadFunc + 124
    Thread 21:
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    0 libSystem.B.dylib 0x98d3392e semaphore_timedwait_trap + 10
    1 …ple.CoreServices.CarbonCore 0x973c3f9e MPWaitOnSemaphore + 125
    2 …ickTimeComponents.component 0x93bf454f DecompressFramesMPTask + 114
    3 …ple.CoreServices.CarbonCore 0x973917ae PrivateMPEntryPoint + 68
    4 libSystem.B.dylib 0x98d60fbd _pthread_start + 345
    5 libSystem.B.dylib 0x98d60e42 thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x3a13ec5c ebx: 0x23c01ac1 ecx: 0x00000000 edx: 0x00000000
    edi: 0x3a139e00 esi: 0x00000000 ebp: 0xbfff5ed8 esp: 0xbfff5c60
    ss: 0x0000001f efl: 0x00010297 eip: 0x23c02248 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x00000006
    Binary Images:
    0x1000 – 0x86bffc com.apple.FinalCutPro 7.0.1 (7.0.1) <3F7907F7-27D6-D3AD-332F-15D972AC9F13> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xc28000 – 0xc2bff7 +KGCore ??? (???) <44304AA1-1D4A-28F7-9ABC-50C7250CFFCF> /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xc33000 – 0xc33ff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0xc37000 – 0xc46fff com.apple.AERegistration 1.2 (77) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xc5a000 – 0xc61fff com.apple.AEProfiling 1.2 (22) <897ABB37-B91C-3C70-7530-A5A455C4E5E9> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xc6b000 – 0xe1efeb com.apple.prokit 5.0.1 (906) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0xedd000 – 0xf4ffef com.apple.ProFX 1.2.3 (1.2.3) /Library/Application Support/ProApps/SharedA/Frameworks/ProFX.framework/Versions/A/ProFX
    0xf71000 – 0xfcbff7 com.apple.proapps.MIO 1.0 (498) <1FFA992F-4D82-684F-B205-4C9015BA14FA> /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0x1007000 – 0x1010ff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x1018000 – 0x1052fff com.apple.CoreMediaIOServicesPrivate 23.0 (951) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    0x106e000 – 0x1097ff7 com.apple.CoreMediaPrivate 20.0 (20.0) <29A9848F-2C1C-BDE4-EADC-2A3C71C1DBC4> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
    0x10aa000 – 0x10ddff3 com.apple.FWAVCPrivate 1.46 (46) <72972BDD-1837-6CFB-2FDD-555456B6E5CE> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
    0x10f2000 – 0x1110fef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
    0x111f000 – 0x1126ff7 com.apple.iChat.IMUtils 5.0.1 (744) <59F22006-D2AB-9D9F-E59C-BAC3AC073ED3> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
    0x112e000 – 0x114cff7 com.apple.iChat.IMFoundation 5.0.1 (744) <2B2A73FF-2178-45AD-518C-C79CBEA73290> /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x1167000 – 0x121cfe7 libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
    0x12a7000 – 0x12e7ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x9674000 – 0x967cff7 com.apple.proapps.mrcheckpro 1.4 (379) <353F1A07-BA95-60CD-D083-4537D209BB69> /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0x96fa000 – 0x96feff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x9765000 – 0x9781ff7 GLRendererFloat ??? (???) <8FF7B576-512C-C2F8-4C0C-967FB3D9EEA2> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x97ab000 – 0x97c2ff3 com.apple.FinalCutPro.Plugins.AudioMixer 7.0.1 (7.0.1) <6377572E-F050-EAD7-B9D5-6FDB122BA147> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x97cd000 – 0x97cdff7 libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0xa098000 – 0xa209ff7 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0xa23a000 – 0xa640fef libclh.dylib ??? (???) <3ACD0D90-B1E9-59DA-729E-7E97092F9A24> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/libclh.dylib
    0xa664000 – 0xa68eff7 com.apple.FinalCutPro.Plugins.AfterEffects 7.0.1 (7.0.1) <4D4E72FF-8D87-3C58-37BA-783A5F9156EB> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0xa696000 – 0xa6e2fff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0xa707000 – 0xa731feb com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0xa752000 – 0xa82aff2 com.apple.FinalCutPro.Plugins.Browser 7.0.1 (7.0.1) <52FAF5BC-3919-CFE4-2703-EEDEC8EF7C2D> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0xa848000 – 0xa84dfff com.apple.FinalCutPro.Plugins.Cache Manager 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0xa852000 – 0xa86cfff com.apple.FinalCutPro.CinemaTools 5.0 (5.0) <599FC934-E4ED-C2CE-148C-593639A68236> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0xa878000 – 0xa882ff9 com.apple.FinalCutPro.Plugins.CTHelper 7.0.1 (7.0.1) <9B81F8A7-24D2-35D9-B1CF-239A75695248> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0xa889000 – 0xa8afff7 com.apple.FinalCutPro.Plugins.EditTape 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0xa8be000 – 0xa918ff5 com.apple.FinalCutPro.Plugins.EDL Export 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0xa92d000 – 0xa935fff com.apple.FinalCutPro.Plugins.Effect Builder 7.0.1 (7.0.1) <20B9388E-2FC1-DAEA-D8EA-8C36F14E5791> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0xa93a000 – 0xa945ffe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 7.0.1 (7.0.1) <8BD11494-835A-EA91-61FF-8D998BF61339> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0xa94e000 – 0xa981ff7 com.apple.FinalCutPro.Plugins.FCS Engine 7.0.1 (7.0.1) <2B5490A6-1F36-95A7-F81F-022497001CE2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0xa98b000 – 0xa99cff7 com.apple.FinalCutPro.Plugins.FilterCustomEd 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0xa9a2000 – 0xa9b7ffb com.apple.FinalCutPro.Plugins.FilterViewer 7.0.1 (7.0.1) <501183D7-04B4-BCE9-1AED-F0863EF448A0> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0xa9bd000 – 0xa9c0ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
    0xa9c6000 – 0xa9e4fea com.apple.FinalCutPro.Plugins.Flash 7.0.1 (7.0.1) <9889AF00-09E4-7E54-B506-5E87D1602974> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0xa9f0000 – 0xa9fdffb com.apple.FinalCutPro.Plugins.GenViewer 7.0.1 (7.0.1) <018E1576-EFCF-492F-67A5-94F8645B6134> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0xaa03000 – 0xaa07fff com.apple.FinalCutPro.Plugins.LayerFileReader 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0xaa0c000 – 0xaa58ff3 com.apple.FinalCutPro.Plugins.Media Manager 7.0.1 (7.0.1) <2B0A237E-7C90-600C-2A92-0A34CBDE6E34> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0xaa62000 – 0xaa74ff0 com.apple.FinalCutPro.Plugins.MolokiniSupport 7.0.1 (7.0.1) <4D2934E3-4B2D-FA0A-1DA4-6ABFC63FB3EA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0xaa83000 – 0xaa97fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0xaaa5000 – 0xaad7ffb com.apple.FinalCutPro.Plugins.Motion Viewer 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0xaae8000 – 0xab03ff3 com.apple.FinalCutPro.Plugins.Movie Analyzer 7.0.1 (7.0.1) <77431356-E2DF-1D36-8078-B21E62C320A1> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0xab12000 – 0xab28ffb com.apple.FinalCutPro.Plugins.Movie Viewer 7.0.1 (7.0.1) <875F0C8C-B093-71D6-0941-7B36F6C4E8EE> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0xab34000 – 0xab38fff com.apple.FinalCutPro.Plugins.NuggetExport 7.0.1 (7.0.1) <974C726C-6066-E70A-CF4C-D33E93496E44> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0xab3d000 – 0xabf6fe7 com.apple.FinalCutPro.Plugins.OMF Audio Export 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0xac09000 – 0xac11ffb com.apple.FinalCutPro.Plugins.Perf Analyzer 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0xac16000 – 0xac2bffb com.apple.FinalCutPro.Plugins.ProAppsIntegration 7.0.1 (7.0.1) <0AC11CF7-E3BB-021E-2A56-847B87AE4CD9> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0xac3b000 – 0xac48ff7 com.apple.FinalCutPro.Plugins.Pulldown Support 7.0.1 (7.0.1) <70C93679-ECF6-AF68-B74D-E8A7BD3068CC> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0xac50000 – 0xac8ffef com.apple.FinalCutPro.Plugins.QTM Reader 7.0.1 (7.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0xac9c000 – 0xaca4ff3 com.apple.FinalCutPro.Plugins.QuickView 7.0.1 (7.0.1) <770D08C6-1F4A-8965-FB7D-47E46CC01C79> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0xaca9000 – 0xacb9ffe com.apple.FinalCutPro.Plugins.Relink Media 7.0.1 (7.0.1) <012A32E5-A541-AA02-C2BD-FDF0976A2C83> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0xacc0000 – 0xacc1fff com.apple.FinalCutPro.Plugins.Text Window 7.0.1 (7.0.1) <733B0EEC-A494-1DBF-4EC5-6BCFC56E1B6A> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0xacc6000 – 0xad5fff2 com.apple.FinalCutPro.Plugins.Timeline Editor 7.0.1 (7.0.1) <2F7B126E-6711-F01B-A0A5-9BDA04E7C3F1> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0xad6e000 – 0xad7ffff com.apple.FinalCutPro.Plugins.Transcoder 7.0.1 (7.0.1) <98CAD32F-D9D8-8E68-2852-7AFEF9332440> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0xad89000 – 0xad9bfff com.apple.FinalCutPro.Plugins.Transition Viewer 7.0.1 (7.0.1) <12936A42-5173-542A-A076-4D040105CAF5> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0xada1000 – 0xadb6ff3 com.apple.FinalCutPro.Plugins.Trimming 7.0.1 (7.0.1) <281D561B-7563-A135-AA24-47168DC412F0> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0xadbc000 – 0xadc2ffb com.apple.FinalCutPro.Plugins.VDUSupport 7.0.1 (7.0.1) <12D2E0FE-F63F-8C52-3FF7-889B38CBA702> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0xadc8000 – 0xadc9ffb com.apple.FinalCutPro.Plugins.Vector Accelerator 7.0.1 (7.0.1) <32116645-63A2-1158-D978-8EF67EA799FA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
    0xadce000 – 0xaddffff com.apple.FinalCutPro.Plugins.VideoLog 7.0.1 (7.0.1) <55CDBFBA-C9B6-0131-1F65-414132A51CC0> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0xade4000 – 0xadfcff7 com.apple.FinalCutPro.Plugins.VoiceOver 7.0.1 (7.0.1) <248C23BB-B191-DECD-B030-95213C02E214> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0xae03000 – 0xae7ffe5 com.apple.FinalCutPro.Plugins.XML Support 7.0.1 (7.0.1) <2791287C-C08E-710D-37BB-01AA77D4D4F4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0xb02c000 – 0xb03afe7 libSimplifiedChineseConverter.dylib ??? (???) <4C9CC2D9-2F13-4465-5447-2516FCD9255B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
    0xb2bc000 – 0xb2cdfe7 com.apple.FCP Uncompressed 422.component 1.6 (1.6) <5CEF993F-DBAC-12FD-57C6-EFA42AB7AEE2> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0xb2d4000 – 0xb2e3ff7 com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (92) <38A3D1ED-F563-7690-3AB6-80B15FD286A2> /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
    0xb2f9000 – 0xb2faff7 com.apple.Helium 3.0.1 (225) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
    0xb527000 – 0xb529ff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0xb52f000 – 0xb593fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <19C0FA03-FC58-CCFE-395D-DD4125A0B811> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    0xb5b3000 – 0xb5f9ffb com.apple.motion.component 1.0 (698) /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0xb700000 – 0xb771fff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0xb77f000 – 0xb781ff7 Motion ??? (???) /Library/Frameworks/Motion.framework/Versions/A/Motion
    0xb787000 – 0xb823ff8 com.apple.procore.framework 4.0 (712) <09EE33B4-412C-FC25-5356-1DE47695BAA6> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0xb862000 – 0xb876fef com.apple.fcp.DVOutputUnit 1.3 (1.3) <4F9BC543-5ADB-7E65-6E1C-5640CA958D63> /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0xbc07000 – 0xbc0cff7 com.apple.AppleMPEG2Codec 1.0.1 (220) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
    0xbc26000 – 0xbc93fe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0xbce0000 – 0xc0bcfe3 QuickTimeH264.scalar ??? (???) /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0xc116000 – 0xc14dfe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0xc15d000 – 0xc20cfe3 com.apple.AppleHDVCodec 1.5 (228) <8D2121A0-BA53-28A2-C9A5-3BED137701DA> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0xc234000 – 0xc24efeb com.apple.AppleIntermediateCodec 1.3 (151) <038597CB-32E7-EBA5-F816-24ED96182EA4> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0xc254000 – 0xc267fe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0xc279000 – 0xc292fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0xc297000 – 0xc2d3fe3 com.apple.QuickTimeFireWireDV.component 7.6.3 (1591.3) <55A49215-3C98-20A3-02EC-FDBAD3D1A69B> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xc3d3000 – 0xc3d7ff7 com.apple.qldisplay.Generic 2.1 (327.3) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/Resources/DisplayBundles/Generic.qldisplay/Contents/MacOS/Generic
    0xc438000 – 0xc438fff com.apple.FxHeliumImage 4.0.0 (1.0) <2CA40CA6-C2E5-D8B8-255D-B8544AE206DD> /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
    0xc442000 – 0xc442ffc com.apple.qmaster.swamp 3.5.1 (3.5.1) <391B264D-7A1E-0A17-D7D0-5970CDCA194F> /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0xc447000 – 0xc47ffff com.apple.motion.MotionBundle 4.0.1 (698) <51BABC62-9FF9-8EFE-744C-D02DB66B789D> /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
    0xc493000 – 0xc49ffff com.apple.PluginManager 1.7.3 (34) <13CD3A05-A00C-4FA7-AD61-2A706A67E390> /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0xc75d000 – 0xc76eff7 com.apple.fxplugframework 1.2.3 (1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0xc781000 – 0xc789ff7 com.apple.QuartzComposer.QCMotionPatch 1.0 (698) /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
    0xc791000 – 0xc795ff3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) <50A3C873-3B3F-0E6E-342A-6E191584750A> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
    0xc7ac000 – 0xc7c5fff com.apple.promath.framework 4.0.1 (698) <7451AC6A-F37F-4E66-F284-59A0AA5FB718> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
    0xc7cf000 – 0xc7e6ff7 libedit.2.dylib ??? (???) /usr/lib/libedit.2.dylib
    0xc7f3000 – 0xc7f8ffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) <874EE8A7-B644-32C8-D8E2-1E4EA379C31B> /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    0xc900000 – 0xc9feff7 com.apple.soundtrackpro.integration 3.0 (3.0) /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0xcc2f000 – 0xcc31fff com.apple.Helium.HCache 2.1.0 (225) <2271D39B-B05E-8EBC-198F-F8E7D6909542> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    0xd0c5000 – 0xd7fafdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
    0xe239000 – 0xe96bfc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
    0xf3a9000 – 0xf4fefec com.apple.Helium.HeliumRender 2.0.1 (225) <492BB54C-BB05-2E10-28AA-ACA28B3E1312> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    0xf554000 – 0xf565fff com.apple.RetimingMath 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
    0xf57a000 – 0xf5b0ff6 com.apple.proinspector.framework 4.0.1 (722) <1AFC9602-DBF3-2577-2647-8CF606DD0F26> /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
    0xf5f3000 – 0xf5f7ff3 com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0xf800000 – 0xfa68ff2 com.apple.motion.filters 4.0.1 (578) <320323A1-D800-333B-F03A-9B2C02B796EB> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0xfbda000 – 0xfbecfff com.apple.motion.Text 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
    0xfbf9000 – 0xfbfbfff +com.sony.bprl.fcpimportplugin 2.10.0 (565) <591CFE63-B788-6A2B-E902-A0274B95EF47> /Library/Application Support/Final Cut Pro System Support/Plugins/SonyImportPlugin.bundle/Contents/MacOS/SonyImportPlugin
    0xfe00000 – 0xfe24ff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0xfe2f000 – 0xfe35ffb com.apple.audio.AppleHDAHALPlugIn 1.7.9 (1.7.9a4) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0xfe3a000 – 0xfe8ffe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) <6F4FE6F8-74E2-3901-2D11-8B9F0164F13A> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0xfeae000 – 0xfeb9ff0 com.apple.fcp.TundraOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0xfec2000 – 0xfeeaff3 com.apple.mio.DAL.T3_VDC 23.0 (951) <686CCCFF-1345-4CA1-2914-5364A4B38569> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Resources/VDC.plugin/Contents/MacOS/VDC
    0xff00000 – 0xff0bff7 com.apple.DVCPROHDVideoOutput 1.3.2 (1.3.2) <273F520B-A3B2-1D46-EEA9-1B0284DD43DB> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0xff13000 – 0xff1ffff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (194) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
    0xff2c000 – 0xff77ff4 com.apple.Bloodhound 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
    0xffa2000 – 0xffe3fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0xffea000 – 0xfff4ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x10000000 – 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) <39D1BFF1-0746-662E-D206-5B884226D735> /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x20091000 – 0x207c1fef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
    0x211fe000 – 0x21934ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
    0x2237f000 – 0x223e4fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <94C8CA82-8E8D-F23F-0771-D065994A65D3> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x223fe000 – 0x224bbfe2 com.apple.DesktopVideoOut 1.2.6 (1.2.6) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x224ea000 – 0x224f0fff com.apple.compressor.FilterUI 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x224f9000 – 0x224faff7 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x22600000 – 0x22ed1ff2 com.apple.ozone.framework 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Ozone
    0x2336d000 – 0x23440fff org.python.python 2.5.4 (2.5) <48AA8ADD-2ED0-73B3-C3AF-D2CEA0B5155A> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
    0x23480000 – 0x235e8ff2 com.apple.ProMedia 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
    0x23659000 – 0x236c1fff com.apple.ProGraphics 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
    0x237dd000 – 0x2395efe2 com.apple.Lithium 4.0.1 (698) <72F7B2B8-3B90-722E-EA44-5F9980C33D7B> /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
    0x239e0000 – 0x23aadff3 com.apple.prochannel.framework 4.0.1 (721) <4174A870-6C7B-C60E-C682-C44DD46774D9> /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
    0x23b4c000 – 0x23ef9ff2 com.apple.motion.TextFramework 4.0.1 (698) <6956DA35-67E6-1A10-D908-E1C7831D7AB5> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/TextFramework
    0x240b5000 – 0x2424bff7 com.apple.motion.Behaviors 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
    0x242ea000 – 0x24486ff8 com.apple.motion.Particles 4.0.1 (698) <4D9D6DFB-C506-518D-BF07-79D19C32C6C1> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
    0x244e0000 – 0x244eaff7 com.apple.compressor.MediaServerAPI 3.5.1 (3.5.1) <04EB0E88-B3E3-370B-5AD5-2C091CFB01D5> /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
    0x24c73000 – 0x24caaff7 com.apple.CompressorKit 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
    0x24cd9000 – 0x24e33ff7 com.apple.AECore 3.5.1 (3.5.1) <3835AD4E-B21E-FF42-C36C-60CD2B644D84> /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x24ecb000 – 0x24f6dfef com.apple.compressor.StompUI 3.5.1 (3.5.1) <14E4B46B-ABAD-F55C-C713-98EBD3629316> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x24fcb000 – 0x24fd6fff com.apple.compressor.StompUtil 3.5.1 (3.5.1) <05D5756A-8FB6-02AD-31E3-2A940181FCAE> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x24fe5000 – 0x24ff0fff com.apple.qmaster.SwampUtil 3.5.1 (3.5.1) <54C5ACDA-90D4-D99F-A20E-6A8CF4A4AE9C> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x34104000 – 0x341ecfe3 com.apple.compressor.StompTypes 3.5.1 (3.5.1) <97A4B508-4B8E-B76B-096E-CCE5E7DA3244> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x34275000 – 0x342a9fff com.apple.qmaster.SwampCore 3.5.1 (3.5.1) <0C856CEA-BE8A-9529-87FE-BD62177D428E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x342d4000 – 0x3439bfe3 com.apple.qmaster.SwampTypes 3.5.1 (3.5.1) <584FD0C4-EA96-635E-4FD6-71C724DD4FC6> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x34428000 – 0x3449cff8 com.apple.qmaster.do 3.5.1 (3.5.1) <2D0FDF8D-E2A7-C6FC-A768-585E2C67D3B9> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x34505000 – 0x3450efff com.apple.qmaster.SwampService 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x3451e000 – 0x34528fff com.apple.qmaster.Status 3.5.1 (3.5.1) <63C2745D-BE37-AD9F-632A-9FEBDC3C9799> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x3453d000 – 0x34548fff com.apple.qmaster.RequestProcessing 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x3455c000 – 0x3456fffb com.apple.qmaster.ServiceControl 3.5.1 (3.5.1) <61D988F2-6DFF-D459-AA41-27F5D687A8DB> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x34588000 – 0x345f5ff3 com.apple.qmaster.ContentControl 3.5.1 (3.5.1) <81871BE6-92C0-1D93-A491-4DE3EA583DF4> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x3463d000 – 0x34702fff com.apple.qmaster.JobControl 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x3478b000 – 0x34796fff com.apple.qmaster.ClusterManager 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x347a5000 – 0x347cfff7 com.apple.qmaster.SwampUI 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x347f4000 – 0x347fffff com.apple.qmaster.SwampExecutor 3.5.1 (3.5.1) <5C54E16E-BBCF-1FBC-61DB-3E30C3B25A2E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x34813000 – 0x3481cfff com.apple.dsppublishing 1.0.0 (115) /Library/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
    0x3482a000 – 0x34862fff com.apple.compressor.ImageProcessing 3.5.1 (3.5.1) <6169DAEC-9D5E-4FB1-13AE-EF5015042A07> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x3488b000 – 0x34a2afeb com.apple.compressor.transcoding 3.5.1 (3.5.1) <00EF53A5-1152-2A2E-2387-50D8AD8E01CE> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x34b50000 – 0x34b79fef com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x34b8a000 – 0x34b8ffe7 com.apple.H264Encoder 1.0 (21) <89E6BDC0-2281-39EA-58CF-4DF45397B61D> /Library/Application Support/ProApps/SharedA/Frameworks/H264Encoder.framework/Versions/A/H264Encoder
    0x34d30000 – 0x34d35ff1 com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
    0x34d3c000 – 0x34e9dff3 com.apple.AutomatorFramework 1.2 (246) <124F4430-6C76-D0CB-9D58-CF004FF3DFD8> /System/Library/Frameworks/Automator.framework/Versions/A/Automator
    0x34f47000 – 0x34f83ff7 com.apple.OSAKit 1.2.1 (76) <6F598EE9-9973-5983-2A71-56FF1AB0081B> /System/Library/Frameworks/OSAKit.framework/Versions/A/OSAKit
    0x34fa7000 – 0x34fedff7 com.apple.AppleScriptKit 1.5.1 (81) <76F7012F-2169-1021-26B5-DDDA990B8926> /System/Library/Frameworks/AppleScriptKit.framework/Versions/A/AppleScriptKit
    0x35030000 – 0x3503dffb com.apple.AppleScriptObjC 1.0.1 (???) <9D9DD1EA-35E1-A031-BB1E-5C257EEE10A8> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
    0x35046000 – 0x35052fe7 libexslt.0.dylib ??? (???) <43856244-CC36-9DE9-3D60-D4F4D6F2825C> /usr/lib/libexslt.0.dylib
    0x35058000 – 0x3506cff7 +com.sony.bprl.fcpexportplugin 2.10.0 (565) /Library/Application Support/Final Cut Pro System Support/Plugins/SonyExportPlugin.bundle/Contents/MacOS/SonyExportPlugin
    0x3f6c0000 – 0x3f6d2ff7 libTraditionalChineseConverter.dylib ??? (???) /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
    0x3fa3c000 – 0x3fa48fff +net.telestream.license 1.0.1.3-GC (1.0.1.3-GC) <105E1717-1FCC-4168-1295-768FB28C4217> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0x41700000 – 0x4174fffb +net.telestream.xdcam 2.2.2.4 (2.2.2.4) <0B97C2C0-6588-97BD-5BEA-5670E6A5DD6D> /Library/QuickTime/Flip4Mac XDCAM.component/Contents/MacOS/Flip4Mac XDCAM
    0x42200000 – 0x42372fff com.apple.QuickTimeStreaming.component 7.6.3 (1591.3) <6E36E094-EB91-F44A-0704-F9E20D796CA4> /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
    0x42900000 – 0x429fdff2 com.apple.Helium.HOpticalFlowAnalyzer 2.0.0 (225) <4C0E1A3C-E2C7-531D-BF60-9035C593C956> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HOpticalFlowAnalyzer.bundle/Contents/MacOS/HOpticalFlowAnalyzer
    0x4334b000 – 0x433c8fe7 com.apple.AppleVADriver 4.7.5 (4.7.5) <3123093D-E8BD-6805-1094-43C8806BD9A8> /System/Library/Extensions/AppleVADriver.bundle/Contents/MacOS/AppleVADriver
    0x43765000 – 0x4395cfc2 +net.telestream.wmv.import 2.2.3.7 (2.2.3.7) <16463171-CBC5-41AC-A577-883C116422EE> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x44300000 – 0x44379fef com.apple.AppleVAH264HW.component 2.0 (1.0) <37782
    Alex Bluffield replied 16 years, 8 months ago 3 Members · 5 Replies
  • Alex Bluffield
    January 21, 2010 at 5:13 pm
    Hi David
    I upgraded to Snow Leopard long before I started this project and my machine has 4GB – 17″ Macbook Pro – I need to update my profile. I’ve found the sequences which are causing the crash, they both contain complex Motion files. The files also crash Motion straight away when I try to open them on their own. The only application I’ve added to computer in the three weeks is Perian Quicktime component, which I’ve since uninstalled – are there any known conflicts with FCS3? The problem appears to be Motion related, although the files and sequences were fine 3 weeks ago. The full Motion error message is:
    Process: Motion [1123]
    Path: /Applications/Motion.app/Contents/MacOS/Motion
    Identifier: com.apple.motion
    Version: 4.0.1 (698)
    Build Info: Motion-6980000~14
    Parent Process: launchd [143]
    Date/Time: 2010-01-21 17:09:28.027 +0000
    Report Version: 6
    Interval Since Last Report: 361658 sec
    Crashes Since Last Report: 34
    Per-App Interval Since Last Report: 3365 sec
    Per-App Crashes Since Last Report: 4
    Crashed Thread: 32
    Thread 0: Dispatch queue: com.apple.main-thread
    0 libstdc++.6.dylib 0x946c8e72 std::string::_Rep::_S_create(unsigned long, unsigned long, std::allocator const&) + 142
    1 libstdc++.6.dylib 0x946cad09 char* std::string::_S_construct
    (char const*, char const*, std::allocator const&, std::forward_iterator_tag) + 85
    2 libstdc++.6.dylib 0x946cb1fb std::basic_string, std::allocator >::basic_string(char const*, std::allocator const&) + 53
    3 com.apple.ImageIO.framework 0x9153d2b3 XMPMeta::RegisterNamespace(char const*, char const*, char const**, unsigned int*) + 181
    4 com.apple.ImageIO.framework 0x9154a0af StartNamespaceDeclHandler(void*, char const*, char const*) + 151
    5 com.apple.ImageIO.framework 0x91542f18 addBinding + 572
    6 com.apple.ImageIO.framework 0x9154939f storeAtts + 794
    7 com.apple.ImageIO.framework 0x91547836 doContent + 2415
    8 com.apple.ImageIO.framework 0x91546ead contentProcessor + 61
    9 com.apple.ImageIO.framework 0x91544169 prologProcessor + 1607
    10 com.apple.ImageIO.framework 0x91543903 XML_ParseBuffer + 133
    11 com.apple.ImageIO.framework 0x9154355a ExpatAdapter::ParseBuffer(void const*, unsigned long, bool) + 68
    12 com.apple.ImageIO.framework 0x915434dd ProcessUTF8Portion(XMLParserAdapter*, unsigned char const*, unsigned long, bool) + 917
    13 com.apple.ImageIO.framework 0x915410d3 XMPMeta::ParseFromBuffer(char const*, unsigned int, unsigned int) + 781
    14 com.apple.ImageIO.framework 0x91540d10 WXMPMeta_ParseFromBuffer_1 + 84
    15 com.apple.ImageIO.framework 0x91540c7e TXMPMeta::ParseFromBuffer(char const*, unsigned int, unsigned int) + 62
    16 com.apple.ImageIO.framework 0x9154096e TXMPMeta
    ::TXMPMeta(char const*, unsigned int) + 70
    17 com.apple.ImageIO.framework 0x9153b970 CreatePropertiesFromXMPData + 203
    18 com.apple.ImageIO.framework 0x9153b87c CGImagePluginReadRawXMPProps + 33
    19 com.apple.ImageIO.framework 0x914fdff3 readProps + 3570
    20 com.apple.ImageIO.framework 0x914faf42 initImageTIFF + 1368
    21 com.apple.ImageIO.framework 0x914fa9e5 _CGImagePluginInitTIFF + 38
    22 com.apple.ImageIO.framework 0x914fa51a makeImagePlus + 487
    23 com.apple.ImageIO.framework 0x914fa1df _CGImageSourceGetPropertiesAtIndexInternal + 75
    24 com.apple.ImageIO.framework 0x914fa160 CGImageSourceCopyPropertiesAtIndex + 127
    25 com.apple.AppKit 0x957b46a0 ImageSourceOptionsForCGImageSource_index_ + 46
    26 com.apple.AppKit 0x957b4463 +[NSBitmapImageRep _imagesWithData:hfsFileType:extension:zone:expandImageContentNow:includeAllReps:] + 455
    27 com.apple.AppKit 0x957e692e +[NSBitmapImageRep _imageRepsWithData:hfsFileType:extension:expandImageContentNow:] + 115
    28 com.apple.AppKit 0x957e65b9 +[NSImageRep _imageRepsWithContentsOfURL:expandImageContentNow:giveUpOnNetworkURLsWithoutGoodExtensions:] + 1119
    29 com.apple.AppKit 0x9587f220 +[NSImageRep _imageRepsWithContentsOfURL:expandImageContentNow:] + 57
    30 com.apple.AppKit 0x9587f1e1 +[NSImageRep imageRepsWithContentsOfFile:] + 91
    31 com.apple.AppKit 0x9587f101 -[NSImage initWithContentsOfFile:] + 52
    32 com.apple.ozone.framework 0x00a61672 -[OZToolbarController _createToolGroupToolbarButton:tools:forItem:isMask:] + 3218
    33 com.apple.ozone.framework 0x00a60420 -[OZToolbarController staticToolbarItemForIdentifier:] + 6864
    34 com.apple.ozone.framework 0x00a63f8b -[OZToolbarController toolbar:itemForItemIdentifier:willBeInsertedIntoToolbar:] + 43
    35 com.apple.AppKit 0x9571e9d4 -[NSToolbar _newItemFromDelegateWithItemIdentifier:propertyListRepresentation:willBeInsertedIntoToolbar:] + 149
    36 com.apple.AppKit 0x9571ca75 -[NSToolbar _newItemFromItemIdentifier:propertyListRepresentation:requireImmediateLoad:willBeInsertedIntoToolbar:] + 312
    37 com.apple.prokit 0x001d7ac8 -[NSProToolbar _newItemFromItemIdentifier:propertyListRepresentation:requireImmediateLoad:willBeInsertedIntoToolbar:] + 139
    38 com.apple.AppKit 0x9571e2ed -[NSToolbar _loadAllPlaceholderItems] + 314
    39 com.apple.AppKit 0x9571d3a6 -[NSToolbar _windowWillShowToolbar] + 119
    40 com.apple.AppKit 0x9571d2bc -[NSWindow _showToolbar:animate:] + 87
    41 com.apple.AppKit 0x9571b57f -[NSWindow setToolbar:] + 738
    42 com.apple.ozone.framework 0x00be40c5 -[OZCanvasView awakeFromNib] + 741
    43 com.apple.CoreFoundation 0x9405db34 -[NSSet makeObjectsPerformSelector:] + 196
    44 com.apple.AppKit 0x95684478 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1566
    45 com.apple.AppKit 0x95682450 loadNib + 257
    46 com.apple.AppKit 0x95681aa3 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 831
    47 com.apple.AppKit 0x95681759 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 158
    48 com.apple.AppKit 0x9571152b -[NSWindowController loadWindow] + 223
    49 com.apple.AppKit 0x956a82da -[NSWindowController window] + 89
    50 com.apple.ozone.framework 0x00766d6c -[OZObjCDocument showWindows] + 156
    51 com.apple.AppKit 0x95a25394 -[NSDocumentController(NSDeprecated) _openDocumentFileAt:display:] + 342
    52 com.apple.ozone.framework 0x00a04cd5 -[OZDocumentController openDocumentWithContentsOfFile:display:] + 277
    53 com.apple.AppKit 0x9590efcf -[NSDocumentController openDocumentWithContentsOfURL:display:error:] + 148
    54 com.apple.AppKit 0x9590d7bf -[NSDocumentController _openDocumentsWithContentsOfURLs:display:presentErrors:] + 169
    55 com.apple.AppKit 0x95a26e87 -[NSDocumentController openDocument:] + 352
    56 com.apple.AppKit 0x95702f86 -[NSApplication sendAction:to:from:] + 112
    57 com.apple.prokit 0x001be308 -[NSProApplication sendAction:to:from:] + 127
    58 com.apple.AppKit 0x95702e39 -[NSMenuItem _corePerformAction] + 435
    59 com.apple.AppKit 0x95702b2a -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
    60 com.apple.AppKit 0x95702a16 -[NSMenu performActionForItemAtIndex:] + 65
    61 com.apple.AppKit 0x957029c9 -[NSMenu _internalPerformActionForItemAtIndex:] + 50
    62 com.apple.AppKit 0x9570292f -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
    63 com.apple.AppKit 0x95702873 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
    64 com.apple.AppKit 0x956f6f79 NSSLMMenuEventHandler + 404
    65 com.apple.HIToolbox 0x95f70e29 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
    66 com.apple.HIToolbox 0x95f700f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    67 com.apple.HIToolbox 0x95f92981 SendEventToEventTarget + 52
    68 com.apple.HIToolbox 0x95fbee3b SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
    69 com.apple.HIToolbox 0x95fe3b20 SendMenuCommandWithContextAndModifiers + 66
    70 com.apple.HIToolbox 0x95fe3ad7 SendMenuItemSelectedEvent + 121
    71 com.apple.HIToolbox 0x95fe39d3 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
    72 com.apple.HIToolbox 0x95fb3212 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 440
    73 com.apple.HIToolbox 0x95fb29a9 _HandleMenuSelection2 + 465
    74 com.apple.HIToolbox 0x95fb27c7 _HandleMenuSelection + 53
    75 com.apple.AppKit 0x956f04ba _NSHandleCarbonMenuEvent + 285
    76 com.apple.AppKit 0x956c5076 _DPSNextEvent + 2304
    77 com.apple.AppKit 0x956c4306 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
    78 com.apple.AppKit 0x9568649f -[NSApplication run] + 821
    79 com.apple.prokit 0x001bea01 NSProApplicationMain + 326
    80 com.apple.motion 0x00005c51 0x1000 + 19537
    81 com.apple.motion 0x00002ea6 0x1000 + 7846
    0 libSystem.B.dylib 0x964780ea kevent + 10
    1 libSystem.B.dylib 0x96478804 _dispatch_mgr_invoke + 215
    2 libSystem.B.dylib 0x96477cc3 _dispatch_queue_invoke + 163
    3 libSystem.B.dylib 0x96477a68 _dispatch_worker_thread2 + 234
    4 libSystem.B.dylib 0x964774f1 _pthread_wqthread + 390
    5 libSystem.B.dylib 0x96477336 start_wqthread + 30
    Thread 2:
    0 libSystem.B.dylib 0x96470856 select$DARWIN_EXTSN + 10
    1 com.apple.CoreFoundation 0x9406dddd __CFSocketManager + 1085
    2 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    3 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 3:
    0 libSystem.B.dylib 0x9645193a semaphore_timedwait_signal_trap + 10
    1 libSystem.B.dylib 0x9647f445 _pthread_cond_wait + 1066
    2 libSystem.B.dylib 0x964ae028 pthread_cond_timedwait_relative_np + 47
    3 …ple.CoreServices.CarbonCore 0x92de4235 TSWaitOnConditionTimedRelative + 242
    4 …ple.CoreServices.CarbonCore 0x92de3f73 TSWaitOnSemaphoreCommon + 511
    5 …ickTimeComponents.component 0x97381035 ReadSchedulerThreadEntryPoint + 4698
    6 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    7 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 4:
    5 …ple.CoreServices.CarbonCore 0x92e3e508 AIOFileThread(void*) + 1127
    Thread 5:
    0 libSystem.B.dylib 0x964518da mach_msg_trap + 10
    1 libSystem.B.dylib 0x96452047 mach_msg + 68
    2 com.apple.CoreFoundation 0x9402e77f __CFRunLoopRun + 2079
    3 com.apple.CoreFoundation 0x9402d864 CFRunLoopRunSpecific + 452
    4 com.apple.CoreFoundation 0x940337a4 CFRunLoopRun + 84
    5 com.apple.QTKit 0x91402a8c QTSurfaceRendererScheduledDisplayThread + 150
    Thread 6:
    5 com.apple.QTKit 0x913fecdd QTVisualContextImageProviderWorkLoop + 114
    Thread 7:
    0 libSystem.B.dylib 0x96451922 semaphore_wait_signal_trap + 10
    1 libSystem.B.dylib 0x9647f45c _pthread_cond_wait + 1089
    2 libSystem.B.dylib 0x964c8503 pthread_cond_wait + 48
    3 com.apple.AppleProResCodec 0x0f04e40b IcpDecompressorComponentDispatch + 1771
    4 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    Thread 8:
    Thread 9:
    5 …ple.CoreServices.CarbonCore 0x92e0816b TimerThread + 97
    Thread 10:
    5 …ple.CoreServices.CarbonCore 0x92e768c2 DeferredTaskThread + 84
    Thread 11:
    5 com.apple.QuickTime 0x97ef46e8 VideoDecodeThread + 83
    Thread 12:
    5 com.apple.DVCPROHDMuxer 0x261f998f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
    Thread 13:
    0 libSystem.B.dylib 0x9647f806 __semwait_signal + 10
    1 libSystem.B.dylib 0x9647f4c2 _pthread_cond_wait + 1191
    2 libSystem.B.dylib 0x96481158 pthread_cond_wait$UNIX2003 + 73
    3 com.apple.ozone.framework 0x0095d21b OZExecutionUnit::executeLoop() + 75
    4 com.apple.ozone.framework 0x0095d31e OZExecutionUnit::executeLoopWrapper(void*) + 94
    5 com.apple.procore.framework 0x018df76c PCThread::startup(void*) + 18
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    Thread 22:
    5 com.apple.qmaster.do 0x246b13b2 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
    6 com.apple.AECore 0x2fde8092 aecore::CThread::runThread() + 34
    7 com.apple.AECore 0x2fde6029 threadProc(void*) + 17
    8 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    9 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 23:
    1 com.apple.AECore 0x2fde80d7 aecore::CThread::runThread() + 103
    2 com.apple.AECore 0x2fde6029 threadProc(void*) + 17
    3 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    4 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 24:
    5 com.apple.DesktopServices 0x92b1b63f TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
    6 …ple.CoreServices.CarbonCore 0x92dc37ae PrivateMPEntryPoint + 68
    7 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    8 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 25:
    0 libSystem.B.dylib 0x96477182 __workq_kernreturn + 10
    1 libSystem.B.dylib 0x96477718 _pthread_wqthread + 941
    2 libSystem.B.dylib 0x96477336 start_wqthread + 30
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    3 com.apple.procore.framework 0x018df583 PCSemaphore::wait() + 45
    4 com.apple.ozone.framework 0x009245fc GLRenderer::findOrCreateRendererBuilder(OZScene*, OZRenderParams&, bool) + 780
    5 com.apple.ozone.framework 0x00925dce GLRenderer::render(OZScene*, OZRenderParams&) + 4046
    6 com.apple.ozone.framework 0x0095f188 OZRenderUnit::processRenderInstruction(OZRenderInstruction*) + 2312
    7 com.apple.ozone.framework 0x0095fa9c OZRenderUnit::execute() + 188
    8 com.apple.ozone.framework 0x0095d295 OZExecutionUnit::executeLoop() + 197
    9 com.apple.ozone.framework 0x0095d31e OZExecutionUnit::executeLoopWrapper(void*) + 94
    10 com.apple.procore.framework 0x018df76c PCThread::startup(void*) + 18
    11 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    12 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 30:
    Thread 31:
    Thread 32 Crashed:
    0 com.apple.motion.TextFramework 0x07fb6248 TXTextLayout::doATSULayout(unsigned int, double, OZRenderState const&) + 1960
    1 com.apple.motion.TextFramework 0x07fbebd8 TXTextLayout::doLayout(OZRenderState const&, PCHash128*) + 2936
    2 com.apple.motion.TextFramework 0x07fc1072 TXTextLayout::prepareForRender(OZRenderParams&) + 66
    3 com.apple.motion.TextFramework 0x07fbef68 TXTextLayout::buildRenderGraph(OZRenderParams&, LiGraphBuilder*, OZRenderGraphState const&) + 456
    4 com.apple.ozone.framework 0x00758c79 OZGroup::makeRenderGraphOfElements(OZRenderParams&, LiGraphBuilder*, OZRenderGraphState const&, bool) + 1609
    5 com.apple.ozone.framework 0x0075c4f8 OZGroup::buildRenderGraph(OZRenderParams&, LiGraphBuilder*, OZRenderGraphState const&) + 232
    6 com.apple.ozone.framework 0x006badf5 OZScene::buildRenderGraph(OZRenderParams&) + 2165
    7 com.apple.ozone.framework 0x00920954 GLRenderer::getFrameNodeForSingleTime(OZScene*, OZRenderParams&, HGRenderer*, double, double, long*) + 1508
    8 com.apple.ozone.framework 0x009212ae GLRenderer::getFrameNodeIncludingFields(OZScene*, OZRenderParams&, HGRenderer*, long*) + 990
    9 com.apple.ozone.framework 0x00921894 GLRenderer::getFrameNode(OZScene*, OZRenderParams&, HGRenderer*, long*) + 164
    10 com.apple.ozone.framework 0x00c8c494 OZRendererBuilderUnit::processRenderInstruction(OZRendererBuilderInstruction*) + 1396
    11 com.apple.ozone.framework 0x00c8c9c9 OZRendererBuilderUnit::execute() + 25
    12 com.apple.ozone.framework 0x0095d295 OZExecutionUnit::executeLoop() + 197
    13 com.apple.ozone.framework 0x0095d31e OZExecutionUnit::executeLoopWrapper(void*) + 94
    14 com.apple.procore.framework 0x018df76c PCThread::startup(void*) + 18
    15 libSystem.B.dylib 0x9647efbd _pthread_start + 345
    16 libSystem.B.dylib 0x9647ee42 thread_start + 34
    Thread 32 crashed with X86 Thread State (32-bit):
    eax: 0x331c6e5c ebx: 0x07fb5ac1 ecx: 0x00000000 edx: 0x00000000
    edi: 0x331c2000 esi: 0x00000000 ebp: 0xb18b4e98 esp: 0xb18b4c20
    ss: 0x0000001f efl: 0x00010297 eip: 0x07fb6248 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
    cr2: 0x00000006
    Binary Images:
    0x1000 – 0x3ffe7 com.apple.motion 4.0.1 (698) /Applications/Motion.app/Contents/MacOS/Motion
    0x143000 – 0x179ff6 com.apple.proinspector.framework 4.0.1 (722) <1AFC9602-DBF3-2577-2647-8CF606DD0F26> /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
    0x19c000 – 0x34ffeb com.apple.prokit 5.0.1 (906) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0x40e000 – 0x41dfff com.apple.AERegistration 1.2 (77) /Applications/Motion.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0x431000 – 0x43dfff com.apple.PluginManager 1.7.3 (34) <13CD3A05-A00C-4FA7-AD61-2A706A67E390> /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0x44a000 – 0x463fff com.apple.promath.framework 4.0.1 (698) <7451AC6A-F37F-4E66-F284-59A0AA5FB718> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
    0x46d000 – 0x474fff com.apple.AEProfiling 1.2 (22) <897ABB37-B91C-3C70-7530-A5A455C4E5E9> /Applications/Motion.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0x47e000 – 0x5e6ff2 com.apple.ProMedia 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
    0x657000 – 0xf28ff2 com.apple.ozone.framework 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Versions/A/Ozone
    0x13c4000 – 0x142cfff com.apple.ProGraphics 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
    0x1548000 – 0x16c9fe2 com.apple.Lithium 4.0.1 (698) <72F7B2B8-3B90-722E-EA44-5F9980C33D7B> /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
    0x174b000 – 0x1818ff3 com.apple.prochannel.framework 4.0.1 (721) <4174A870-6C7B-C60E-C682-C44DD46774D9> /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
    0x18b7000 – 0x1953ff8 com.apple.procore.framework 4.0 (712) <09EE33B4-412C-FC25-5356-1DE47695BAA6> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0x1992000 – 0x19b0fef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
    0x19bf000 – 0x19c8ff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x19d0000 – 0x1aa3fff org.python.python 2.5.4 (2.5) <48AA8ADD-2ED0-73B3-C3AF-D2CEA0B5155A> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
    0x1ae3000 – 0x1b47fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <19C0FA03-FC58-CCFE-395D-DD4125A0B811> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    0x1b67000 – 0x1b68ff7 com.apple.Helium 3.0.1 (225) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
    0x1b6c000 – 0x1b6cff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x1b70000 – 0x1bbcfff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x1be1000 – 0x1bf2ff7 com.apple.fxplugframework 1.2.3 (1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0x1c05000 – 0x1c1cff7 libedit.2.dylib ??? (???) /usr/lib/libedit.2.dylib
    0x1c29000 – 0x1c3afff com.apple.RetimingMath 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
    0x1c4f000 – 0x1c4ffff com.apple.FxHeliumImage 4.0.0 (1.0) <2CA40CA6-C2E5-D8B8-255D-B8544AE206DD> /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
    0x1c55000 – 0x1daafec com.apple.Helium.HeliumRender 2.0.1 (225) <492BB54C-BB05-2E10-28AA-ACA28B3E1312> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    0x1e00000 – 0x1eb5fe7 libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
    0x2534000 – 0x26a5ff7 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x26d6000 – 0x26f2ff7 GLRendererFloat ??? (???) <8FF7B576-512C-C2F8-4C0C-967FB3D9EEA2> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x27d9000 – 0x27deffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) <874EE8A7-B644-32C8-D8E2-1E4EA379C31B> /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    0x71c8000 – 0x75cefef libclh.dylib ??? (???) <3ACD0D90-B1E9-59DA-729E-7E97092F9A24> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x786a000 – 0x787cfff com.apple.motion.Text 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
    0x7889000 – 0x7891ff7 com.apple.proapps.mrcheckpro 1.4 (379) <353F1A07-BA95-60CD-D083-4537D209BB69> /Applications/Motion.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0x78ca000 – 0x78ccff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x78d2000 – 0x7943fff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x7951000 – 0x7997ffb com.apple.motion.component 1.0 (698) /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x799d000 – 0x799fff7 Motion ??? (???) /Library/Frameworks/Motion.framework/Versions/A/Motion
    0x7a48000 – 0x7a4cff3 com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x7a51000 – 0x7a57ffb com.apple.audio.AppleHDAHALPlugIn 1.7.9 (1.7.9a4) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x7a5f000 – 0x7bf5ff7 com.apple.motion.Behaviors 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
    0x7c94000 – 0x7cdfff4 com.apple.Bloodhound 4.0.1 (698) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
    0x7d0a000 – 0x7ea6ff8 com.apple.motion.Particles 4.0.1 (698) <4D9D6DFB-C506-518D-BF07-79D19C32C6C1> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
    0x7f00000 – 0x82adff2 com.apple.motion.TextFramework 4.0.1 (698) <6956DA35-67E6-1A10-D908-E1C7831D7AB5> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/Versions/A/TextFramework
    0x8395000 – 0x83c3ff7 com.apple.prokit.SnowLeopardPanels 5.0.1 (906) <200EE10C-484D-A71C-ADFF-4DCC8411C31D> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/SnowLeopardPanels.bundle/Contents/MacOS/SnowLeopardPanels
    0x9fa9000 – 0x9faaff7 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0xc4fa000 – 0xc4faff7 libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0xc57b000 – 0xc58dff7 libTraditionalChineseConverter.dylib ??? (???) /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
    0xc5b7000 – 0xc5c5fe7 libSimplifiedChineseConverter.dylib ??? (???) <4C9CC2D9-2F13-4465-5447-2516FCD9255B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
    0xc6c4000 – 0xc6c9ff7 com.apple.AppleMPEG2Codec 1.0.1 (220) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
    0xc965000 – 0xc965ffc com.apple.qmaster.swamp 3.5.1 (3.5.1) <391B264D-7A1E-0A17-D7D0-5970CDCA194F> /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0xc9a3000 – 0xc9a3ffc com.apple.compressor.stomp 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Compressor
    0xcd6e000 – 0xcd7ffe7 com.apple.FCP Uncompressed 422.component 1.6 (1.6) <5CEF993F-DBAC-12FD-57C6-EFA42AB7AEE2> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0xcf0c000 – 0xcf18fff +net.telestream.license 1.0.1.3-GC (1.0.1.3-GC) <105E1717-1FCC-4168-1295-768FB28C4217> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0xcf21000 – 0xcf23fff com.apple.Helium.HCache 2.1.0 (225) <2271D39B-B05E-8EBC-198F-F8E7D6909542> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    0xe03a000 – 0xe089ffb +net.telestream.xdcam 2.2.2.4 (2.2.2.4) <0B97C2C0-6588-97BD-5BEA-5670E6A5DD6D> /Library/QuickTime/Flip4Mac XDCAM.component/Contents/MacOS/Flip4Mac XDCAM
    0xf044000 – 0xf0b1fe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0xf600000 – 0xf624ff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0xf62f000 – 0xf6a8fef com.apple.AppleVAH264HW.component 2.0 (1.0) <377823AD-6C3A-F949-2F12-74B05AE475B1> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
    0xf83c000 – 0xf878fe3 com.apple.QuickTimeFireWireDV.component 7.6.3 (1591.3) <55A49215-3C98-20A3-02EC-FDBAD3D1A69B> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xf884000 – 0xf89efeb com.apple.AppleIntermediateCodec 1.3 (151) <038597CB-32E7-EBA5-F816-24ED96182EA4> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0xf8a4000 – 0xf8bdfe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0xf94c000 – 0xf983fe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0xf993000 – 0xf9a6fe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x10000000 – 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) <39D1BFF1-0746-662E-D206-5B884226D735> /Applications/Motion.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x203d7000 – 0x205cefc2 +net.telestream.wmv.import 2.2.3.7 (2.2.3.7) <16463171-CBC5-41AC-A577-883C116422EE> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x2063d000 – 0x206ecfe3 com.apple.AppleHDVCodec 1.5 (228) <8D2121A0-BA53-28A2-C9A5-3BED137701DA> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x213c2000 – 0x21524fe2 +net.telestream.wmv.advanced 2.2.3.7 (2.2.3.7) <33EA1744-8FF4-4991-97C8-279DB599B913> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0x230ce000 – 0x230d2ff3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) <50A3C873-3B3F-0E6E-342A-6E191584750A> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
    0x23151000 – 0x231a6fe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) <6F4FE6F8-74E2-3901-2D11-8B9F0164F13A> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x2339e000 – 0x233d5ff7 com.apple.CompressorKit 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
    0x23404000 – 0x2340eff7 com.apple.compressor.MediaServerAPI 3.5.1 (3.5.1) <04EB0E88-B3E3-370B-5AD5-2C091CFB01D5> /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
    0x23504000 – 0x2350ffff com.apple.compressor.StompUtil 3.5.1 (3.5.1) <05D5756A-8FB6-02AD-31E3-2A940181FCAE> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x2351e000 – 0x23552fff com.apple.qmaster.SwampCore 3.5.1 (3.5.1) <0C856CEA-BE8A-9529-87FE-BD62177D428E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x24324000 – 0x243c6fef com.apple.compressor.StompUI 3.5.1 (3.5.1) <14E4B46B-ABAD-F55C-C713-98EBD3629316> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x24524000 – 0x2452ffff com.apple.qmaster.SwampUtil 3.5.1 (3.5.1) <54C5ACDA-90D4-D99F-A20E-6A8CF4A4AE9C> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x2453c000 – 0x24545fff com.apple.qmaster.SwampService 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x24555000 – 0x2455ffff com.apple.qmaster.Status 3.5.1 (3.5.1) <63C2745D-BE37-AD9F-632A-9FEBDC3C9799> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x24574000 – 0x2457ffff com.apple.qmaster.RequestProcessing 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x24593000 – 0x24599fff com.apple.compressor.FilterUI 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x2469e000 – 0x24712ff8 com.apple.qmaster.do 3.5.1 (3.5.1) <2D0FDF8D-E2A7-C6FC-A768-585E2C67D3B9> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x2477b000 – 0x24786fff com.apple.qmaster.ClusterManager 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x24851000 – 0x24864ffb com.apple.qmaster.ServiceControl 3.5.1 (3.5.1) <61D988F2-6DFF-D459-AA41-27F5D687A8DB> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x2487d000 – 0x248eaff3 com.apple.qmaster.ContentControl 3.5.1 (3.5.1) <81871BE6-92C0-1D93-A491-4DE3EA583DF4> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x24932000 – 0x2493dfff com.apple.qmaster.SwampExecutor 3.5.1 (3.5.1) <5C54E16E-BBCF-1FBC-61DB-3E30C3B25A2E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x25580000 – 0x255aaff7 com.apple.qmaster.SwampUI 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x255cf000 – 0x255d8fff com.apple.dsppublishing 1.0.0 (115) /Library/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
    0x255e6000 – 0x255ebfe7 com.apple.H264Encoder 1.0 (21) <89E6BDC0-2281-39EA-58CF-4DF45397B61D> /Library/Application Support/ProApps/SharedA/Frameworks/H264Encoder.framework/Versions/A/H264Encoder
    0x25700000 – 0x25740ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
    0x25800000 – 0x25838fff com.apple.compressor.ImageProcessing 3.5.1 (3.5.1) <6169DAEC-9D5E-4FB1-13AE-EF5015042A07> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x25fe2000 – 0x2600bfef com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x261e2000 – 0x26247fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <94C8CA82-8E8D-F23F-0771-D065994A65D3> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x2af00000 – 0x2b168ff2 com.apple.motion.filters 4.0.1 (578) <320323A1-D800-333B-F03A-9B2C02B796EB> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0x2b4a4000 – 0x2b4afff7 com.apple.DVCPROHDVideoOutput 1.3.2 (1.3.2) <273F520B-A3B2-1D46-EEA9-1B0284DD43DB> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x2bf54000 – 0x2bf95fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x2bf9c000 – 0x2bfa8fff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (194) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
    0x2bfb0000 – 0x2bfbaff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x2c882000 – 0x2c888ff7 com.apple.qldisplay.Movie 2.1 (327.3) <2BCD44AB-82A2-E373-71D5-C5752CDC6B07> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/Resources/DisplayBundles/Movie.qldisplay/Contents/MacOS/Movie
    0x2d700000 – 0x2d7bdfe2 com.apple.DesktopVideoOut 1.2.6 (1.2.6) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x2d972000 – 0x2da5afe3 com.apple.compressor.StompTypes 3.5.1 (3.5.1) <97A4B508-4B8E-B76B-096E-CCE5E7DA3244> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x2ecad000 – 0x2f089fe3 QuickTimeH264.scalar ??? (???) /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0x2fdce000 – 0x2ff28ff7 com.apple.AECore 3.5.1 (3.5.1) <3835AD4E-B21E-FF42-C36C-60CD2B644D84> /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x2ffc0000 – 0x30087fe3 com.apple.qmaster.SwampTypes 3.5.1 (3.5.1) <584FD0C4-EA96-635E-4FD6-71C724DD4FC6> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x30114000 – 0x301d9fff com.apple.qmaster.JobControl 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x30262000 – 0x30401feb com.apple.compressor.transcoding 3.5.1 (3.5.1) <00EF53A5-1152-2A2E-2387-50D8AD8E01CE> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x33b00000 – 0x33c72fff com.apple.QuickTimeStreaming.component 7.6.3 (1591.3) <6E36E094-EB91-F44A-0704-F9E20D796CA4> /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
    0x8f611000 – 0x8fa52fe7 com.apple.GeForce8xxxGLDriver 1.6.6 (6.0.6) <205911D0-3CE3-D53C-289B-319A4E4BA153> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
    0x8fe00000 – 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
    0x90003000 – 0x907e64b7 com.apple.CoreGraphics 1.536.12 (???) <263EB5FC-DEAD-7C5B-C486-EC86C173F952> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x907e7000 – 0x90811ff7 com.apple.shortcut 1.1 (1.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x90817000 – 0x9081eff7 com.apple.iChat.IMUtils 5.0.1 (744) <59F22006-D2AB-9D9F-E59C-BAC3AC073ED3> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
    0x9081f000 – 0x9081fffb libffi.dylib ??? (???) <58985323-6EC6-9AD2-B9F0-8787C0B2791C> /usr/lib/libffi.dylib
    0x90820000 – 0x9085efe7 com.apple.MediaKit 10.0 (472) <8B1C89AF-6A2A-8D01-D723-22A4DBEA7760> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x908aa000 – 0x908c8ff7 com.apple.CoreVideo 1.6.0 (43.1) <1FB01BE0-B013-AE86-A063-481BB547D2F5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x908c9000 – 0x908c9ff7 com.apple.CoreServices 44 (44) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x908ca000 – 0x9090cfe7 libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x9090d000 – 0x90dbbfe7 com.apple.VideoToolbox 0.420.18 (420.18) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x90dbc000 – 0x90dbcff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
    0x90dbd000 – 0x90ee1ff7 com.apple.CoreAUC 5.03.2 (5.03.2) <38C77DF1-6F98-4ABF-BE8F-ADA70E9C622D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x90ee2000 – 0x90f73fe7 com.apple.print.framework.PrintCore 6.1 (312.3) <6D4322AF-703C-CC19-77B4-53E6D3BB18D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x90f74000 – 0x90fc4ff7 com.apple.framework.familycontrols 2.0 (2.0) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x90fc5000 – 0x910c6fe7 libxml2.2.dylib ??? (???) /usr/lib/libxml2.2.dylib
    0x910e8000 – 0x911a1fe7 libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
    0x911a2000 – 0x91210ff7 com.apple.ISSupport 1.9.2 (50) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
    0x91211000 – 0x91313fef com.apple.MeshKitIO 1.0 (49.0) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x9132d000 – 0x9132dff7 com.apple.Accelerate 1.5 (Accelerate 1.5) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x9132e000 – 0x9146dfe3 com.apple.QTKit 7.6.3 (1591.3) <18F25C19-F0B8-5907-D6D6-65EC53DF0D3B> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x914f6000 – 0x916b2fef com.apple.ImageIO.framework 3.0.1 (3.0.1) <598CF4F9-7542-E1A7-26D2-584933497A2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x916e5000 – 0x916f9fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
    0x916fa000 – 0x916faff7 com.apple.quartzframework 1.5 (1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x916fb000 – 0x91722ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x91723000 – 0x9175aff7 com.apple.CoreMedia 0.420.18 (420.18) <43747711-B334-B0C7-4971-15FA586DAFBF> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x9175b000 – 0x91761ff7 com.apple.DisplayServicesFW 2.2 (2.2) <72C790A9-F4D2-DA92-015B-4CAF478FC0C2> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x91762000 – 0x9178cff7 com.apple.framework.Admin 4.0 (4.0) <4A434473-A6C1-3F40-2928-16CFF1222FA1> /System/Library/PrivateFrameworks/Admin.framework/Versions/A/Admin
    0x91795000 – 0x9179cfff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x9179d000 – 0x917a7fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x917a8000 – 0x91822fef com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x91823000 – 0x91a35fff com.apple.RawCamera.bundle 2.2.1 (477) <10937A0D-0856-1B69-AE27-43BC15B7DD21> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x91d2b000 – 0x91d69ff7 com.apple.QuickLookFramework 2.1 (327.3) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x91de4000 – 0x91e08ff7 libJPEG.dylib ??? (???) <649E1974-A527-AC0B-B3F4-B4DC30484070> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91e09000 – 0x91ea6fe3 com.apple.LaunchServices 362 (362) <8BE1C1A1-BF71-CE07-F3FB-6057D47AF461> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x91ea7000 – 0x91eaafe7 libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x91eab000 – 0x91f24ff7 com.apple.PDFKit 2.5 (2.5) <58603BDB-337F-FBE3-EB11-7C31CF261995> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x91f25000 – 0x9233bff7 libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x9233c000 – 0x923e9fe7 libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
    0x923ea000 – 0x9245bff7 com.apple.iLifeMediaBrowser 2.1.3 (346.0.3) /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
    0x9245c000 – 0x92463ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x92464000 – 0x924a0fff com.apple.CoreMediaIOServices 124.0 (850) <5F9B1AA3-8BB3-4E8C-2A31-F8FD5EC3F28A> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
    0x924a1000 – 0x926ccff3 com.apple.QuartzComposer 4.1 (156.10) <24293329-50D7-D12F-51B3-57976A4E52B1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x926cd000 – 0x926d1ff7 IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x926df000 – 0x92a46ff7 com.apple.QuartzCore 1.6.1 (227.8) <8B90AB08-46A4-1C5C-4E71-C6AB652477B9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x92a47000 – 0x92b18fe3 ColorSyncDeprecated.dylib ??? (???) <1CEB1F35-EF10-A63D-AD9E-D7BD391D4719> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x92b19000 – 0x92bf3ff3 com.apple.DesktopServices 1.5.3 (1.5.3) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x92bf4000 – 0x92cfbfe3 com.apple.DiskImagesFramework 10.6 (281) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x92cfc000 – 0x92d1bfe3 libexpat.1.dylib ??? (???) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
    0x92d1c000 – 0x92d1dff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x92d1e000 – 0x92d61ff7 com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x92d62000 – 0x92d9cffb libFontRegistry.dylib ??? (???) <72342297-E8D6-B071-A752-014134129282> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x92d9d000 – 0x930bcfe7 com.apple.CoreServices.CarbonCore 861.2 (861.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x930bd000 – 0x93113ff7 com.apple.MeshKitRuntime 1.0 (49.0) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
    0x93114000 – 0x931f2fff com.apple.QuickTimeMPEG4.component 7.6.3 (1591.3) <92D35422-4D67-4B29-B803-50BACDBA47D8> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x931f3000 – 0x93211ff7 com.apple.iChat.IMFoundation 5.0.1 (744) <2B2A73FF-2178-45AD-518C-C79CBEA73290> /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x93212000 – 0x93281ff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x93282000 – 0x9331efe7 com.apple.ApplicationServices.ATS 4.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x9331f000 – 0x9333ffe7 com.apple.opencl 12 (12) <2DB56F60-577B-6724-5708-7B082F62CC0F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x93387000 – 0x933ebffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x933ec000 – 0x93518fe3 com.apple.audio.toolbox.AudioToolbox 1.6.1 (1.6.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x93519000 – 0x9353ffff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x93540000 – 0x9358dfeb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
    0x9358e000 – 0x9358eff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x9358f000 – 0x935d3ff3 com.apple.coreui 2 (113) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x935d6000 – 0x935e3ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x935e4000 – 0x935e7ff7 libCGXType.A.dylib ??? (???) <483FCF1C-066B-D210-7355-ABC48CA9DB2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x935e8000 – 0x935eefff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x935ef000 – 0x936fcff7 com.apple.MediaToolbox 0.420.18 (420.18) <31935D52-1F8D-4AB2-CCA5-4CF615CBCE24> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x936fd000 – 0x93708ff7 libCSync.A.dylib ??? (???) <9292E6E3-70C1-1DD7-4213-1044F0FA8381> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x93709000 – 0x93712ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x93713000 – 0x93720ff7 libbz2.1.0.dylib ??? (???) <495732E1-2AC4-44FC-E633-4CBCC503B924> /usr/lib/libbz2.1.0.dylib
    0x93721000 – 0x93741fe7 libresolv.9.dylib ??? (???) /usr/lib/libresolv.9.dylib
    0x93742000 – 0x93745ff7 libCoreVMClient.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x93746000 – 0x9377aff7 libssl.0.9.8.dylib ??? (???) /usr/lib/libssl.0.9.8.dylib
    0x9377b000 – 0x9378dff7 com.apple.CoreMediaAuthoring 0.677 (677) <197EAB61-ACCE-E5AC-08FA-2A2D4E122E86> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x938a5000 – 0x939d3fe7 com.apple.CoreData 102.1 (250) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x939d4000 – 0x93a6cfe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x93a8f000 – 0x93affff3 com.apple.AppleVAFramework 4.7.5 (4.7.5) <464A915D-E670-FA22-7799-454259D42B82> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x93b00000 – 0x93b28ff7 libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
    0x93b6c000 – 0x93bb2ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
    0x93bb3000 – 0x93c13fe7 com.apple.CoreText 3.1.0 (???) <79FD1B5C-2F93-4C5D-B07B-4DD9088E67DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x93c14000 – 0x93cf1ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x93cf2000 – 0x93d2fff7 com.apple.SystemConfiguration 1.10.1 (1.10.1) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x93d30000 – 0x93d52fef com.apple.DirectoryService.Framework 3.6 (621.1) <3ED4949F-9604-C109-6586-5CE5F421182B> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93d53000 – 0x93e06fff libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x93e07000 – 0x93e3cff7 libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x93e3d000 – 0x93eabff7 com.apple.QuickLookUIFramework 2.1 (327.3) <2F51D9CB-F827-E0AF-F201-5F4244C0D02A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/
  • David Bogie
    January 21, 2010 at 7:49 pm
    Pereian is a known issue but it’s not a universal problem.
    You must remove ALL of Perian.
    Your crash log looks noting like mine but my crashing was in FCP. Can you post that one? You only need to include the thread that actually crashed unless someone can decipher it. They’ll ask for more if they need to.
    bogiesan
  • Alex Bluffield
    January 21, 2010 at 7:54 pm
    Sorry to add yet another post to this thread – I’ve pinpointed 2 Motion files that instantly crash Motion when I open them. These motion files were in sequences in FCP and cause FCP to crash. I’ve now found a workaround – I created another user account and can open the files fine in Motion in that account and same with the FCP project.
    They still crash under my Admin account and I have absolutely know idea why or what the hell is going on. If anyone has an answer or has experienced the same, I’d be interested to know.
    Best,
    Alex.
    Alex Bluffield
    Final Cut Pro Editor
    W: https://www.a2bpostproduction.co.uk
  • David Roth weiss
    January 21, 2010 at 8:50 pm
    [Dave LaRonde] “David Roth Weiss is usually the one to write about this.”
    I thought I heard my name being used in vain…
    [Dave LaRonde] “Run Apple Disk Utility and repair permissions. Buy and run Disk Warrior; no serious Final Cut suite should be without it.
    Dave, at least somebody’s been paying attention…
    Alex, follow Dave’s advice… He knows what I’ve been talking about.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Alex Bluffield
    January 21, 2010 at 9:00 pm
    Thankyou David & David.
    The root of the problem appears to be a corrupt font which I used in the two Motion files causing it to crash. I ran Font Book which detected the font was duplicated in two places (seems minor?). Now attempting to fix under my Admin account. Have repaired permissions and trashed Motion preferences. Also downloading trial version of Digital Rebellion’s FCS Maintenance Pack. Will check out disk warrior. Can’t believe a font can cause this much trouble! Thanks guys.
    Alex Bluffield
