Activity Forums Adobe After Effects Project Settings
  • Project Settings
    Posted by Bala Ulab on August 13, 2010 at 6:24 am
    I need to create a video presentation that will be played using DVD players and Computers.
    Can any one suggest me the Project and composition settings.
    Thanks in Advance
    Bala
    Bala Ulab replied 16 years ago 2 Members · 3 Replies
  • Bala Ulab
    August 14, 2010 at 3:14 am
    It is going to be played in 4*3 TV. Im using Windows
    Bala
  • Karl-jason Mawdsley
    August 18, 2010 at 7:53 am
    Hi Bala,
    You need to use with either the NTSC DV or the PAL D1/DV preset depending on which country you are in. Those are the 2 standard resolution 4×3 settings.
    When it comes to rendering out – if you’re playing from a DVD then you need to select the MPEG2 format in your output module.
    Hope this helps.
    KJ Mawdsley
    Editor/Mograph Designer
  • Bala Ulab
    August 24, 2010 at 4:44 am
    Thanks Karl-jason Mawdsley.
    Bala
