Activity › Forums › VEGAS Pro › Project Settings vs. Event Settings vs. Render Settings question REPOST
  • Project Settings vs. Event Settings vs. Render Settings question REPOST
    Posted by Kelly Griffin on August 30, 2012 at 10:18 pm
    I’m sorry for re-posting this question, but I’m still left wondering if one item “has power” over the other (?)
    For example: Let’s say I shoot HD footage that’s upper field first. From there I create a TV spot going out to two cable providers; one wants upper field first, one wants progressive.
    For the one that wants progressive, if I have all my footage on the timeline as upper field first, do I have to change the project settings and the individual event settings and the render settings to progressive as well, or does changing project settings “override” what’s selected on individual events? Or, does changing render settings do that?
    I’d really like to understand this, but the only reply to my original post talked more about the ability to change all three, not an explanation of how they are (or aren’t) affected by each other.
    Thank you!
    –Kelly
    John Rofrano replied 14 years, 1 month ago 2 Members · 3 Replies
  • John Rofrano
    August 31, 2012 at 5:28 pm
    [Kelly Griffin] “For the one that wants progressive, if I have all my footage on the timeline as upper field first, do I have to change the project settings and the individual event settings and the render settings to progressive as well, or does changing project settings “override” what’s selected on individual events? Or, does changing render settings do that?”
    All you would need to do in that case is to render using a progressive template. Nothing else meeds to change.
    [Kelly Griffin] “I’d really like to understand this, but the only reply to my original post talked more about the ability to change all three, not an explanation of how they are (or aren’t) affected by each other.”
    Let me try and explain.
    Project Settings: These are for the human while editing. Vegas (unlike many other NLE’s) will dynamically show you everything as if it all matched the project properties. For example, if you set them to progressive, Vegas will deinterlace any interlaced footage on the timeline on-the-fly to show you what your project would look like as if it were progressive. This is why I usually recommend that your project properties match your render properties because only then will you get true WYSIWYG (What You See Is What You Get). Sometimes you can’t do this because you are rendering to multiple formats. Then I recommend that you set your project to match the format of your source. Having your project match the format of your source has an added advantage that Vegas doesn’t have to convert anything on-the-fly and so playback performance is better.
    Even/Media Properties: These MUST be set to match what the media really is. They should only be changed if Vegas interprets your media incorrectly. (e.g., Vegas thinks your media is Upper Field First when it’s really Lower Field First). NEVER set these to something that doesn’t actually match the real media because this is how Vegas knows if it needs to deinterlace or change the field order. (e.g., don’t lie to Vegas and tell it something is progressive when it’s not, the results won’t be pretty). The only exception is if you are using a plug-in that asks you to change these settings. Once such plug-in is BCC UpRez which asks that you set interlaced footage to progressive because UpRez will handle the deinterlacing for you.
    Render Properties: These can be anything you want and obviously should reflect your final desired format. This how you turn 16:9 into 4:3 or interlaced into progressive. If you’ve set your project up properly and all of your media is set properly, rendering should never surprise you and always give you what you asked for.
    Feel free to ask more questions if this doesn’t cover when you needed to know.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kelly Griffin
    August 31, 2012 at 11:50 pm
    Thank you, John. Very, very helpful.
    The light bulb has come on.
    –Kelly
  • John Rofrano
    September 1, 2012 at 1:01 pm
    [Kelly Griffin] “The light bulb has come on.”
    …and now you can see all the clutter in the room. lol 😀
    You’re welcome.
    ~jr
