Activity Forums VEGAS Pro project settings for mixed media timeline.
  • project settings for mixed media timeline.
    Posted by Chris Morley on July 16, 2010 at 4:50 pm
    Hello,
    I was just wondering what project setting will yield the best results if using both progressive mini DV (16:9) and AVCHD footage (720p)on the timeline, if the final output is going to be SD (DVD)?
    Does it make a difference whether the settings are for Mini DV or for AVCHD? (I have Vegas Pro 8 so don’t get the option for AVCHD so have to go for 720p HDV – by the way) I know that the pixel aspect ratio is different for both types.
    Has anyone else mixed these two formats?? I’m in PAL land.
    Thanks in advance.
    John Rofrano replied 16 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    July 18, 2010 at 12:42 pm
    If your target is SD and you have SD footage mixed with HD then set your project for SD (i.e., PAL DV Widescreen).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
