Activity Forums Apple Final Cut Pro Project (sequence) duration..
  • Project (sequence) duration..
    Posted by David Battistella on August 5, 2011 at 2:23 pm
    Finished project.
    Sequence is 6 min 42 seconds
    Project is 14 minutes 41 seconds.
    Not one shred of media past the 6:42 mark.
    Anyone know how to trim the Project to be something like 6:52?
    I have to say that the built in help in FCP X sucks balls and in pretty much useless.
    Copy pasting the selected clips give me a timeline of the exact same duration 14:41. Very strange. I don’t need the 8 minutes of BLACK at the end of the project.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
    Brice Shultz replied 15 years ago 5 Members · 6 Replies
  • Jeremy Garchow
    August 5, 2011 at 2:44 pm
    What do you mean it’s 14m? When you export?
  • Steve Connor
    August 5, 2011 at 2:59 pm
    I know it’s obvious but are you sure there isn’t a black slug at the end of the project?
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Gerald Baria
    August 5, 2011 at 3:13 pm
    You probably have a gap clip at the end part of you project. Just click it and press backspace.
    Quobetah
    New=Better
  • David Battistella
    August 5, 2011 at 3:50 pm
    [Gerald Baria] “You probably have a gap clip at the end part of you project. Just click it and press backspace.”
    Yes.
    It was indeed a GAP clip. One that I had put in to tack material to at the end of the timline. The material was gone but the GAP clip remainded.
    Dragged the GAP clip back to the time I wanted and life is good again.
    David
    Lord Herbert
  • David Battistella
    August 5, 2011 at 3:54 pm
    Yep.
    It was 14 minutes after export.
    David
    Lord Herbert
  • Brice Shultz
    August 10, 2011 at 5:48 pm
    I am having the same situation, I have a 4 minute long project but when it’s rendering it’s coming in at over 30 minutes. I checked the clips list and I do not have a slug at the end of the time line that would cause this. Any help would be awesome.
    Is there any way to export selected (if I can’t get by with exerting all the black and trimming after in another program)?
